Related Resources: fluid flow
Cube Flow Perpendicular Edge Surface Drag, Drag Coefficient Equation and Calculator
Cube Flow Perpendicular to Edge Surface Drag, Drag Coefficient Equation and Calculator
Drag Equation:
Illustration
Description
L / d
Cd
Re / 104
Frontal Area
Cube
Edge Flow |
0.80
100
20.5 d2
D = Drag (N);
ρ = fluid density (kg/m3);
L = Length (m);
d = Depth (m);
A = frontal area (m2);
V = fluid velocity (m/sec);
d = Diameter (m);
Density of air = 1.225 kg/m3
