Schedule 40 Steel Pipe Sizes and Dimensions ASME/ANSI B36.10/19
Fluid
Flow Table of Contents
Hydraulic and
Pneumatic Knowledge
This chart gives dimensional - size data for American National Standard Schedule 40 Welded and Seamless Steel Pipe.
- Schedule 80 Steel Pipe Sizes & Dimensions ANSI
- Schedule 40 Plastic PVC, CPVC Pipe Sizes & Dimensions
- Schedule 80 Plastic PVC, CPVC Pipe Sizes & Dimension
- Velocity and Flow Capacity of Oil Standard Tubes
- Velocity and Flow Capacity of Oil Schedule 40 Pipe
- Velocity and Flow Capacity of Oil Schedule 80 Pipe
- Velocity and Flow Capacity of Oil Schedule 160 Pipe
Reference ANSI/ASME B36.10M-1995 Wrought Steel Pipe seamless and welded.
Diameter
(Inches) |
Wall
Weight
per Foot, (Lbs) |
Nominal
Inside
Outside
Thickness
(in) |
Pipe
1/8
.269
.405
.068
.24
1/4
.364
.540
.088
.42
3/8
.493
.675
.091
.57
1/2 |
.622
.840
.109
.85
3/4
.824
1.050
.113
1.13
1
1.049
1.315
.133
1.68
11/4
1.380
1.660
.140
2.27
1 1/2
1.610
1.900
.145
2.72
2
2.067
2.375
.154
3.65
21/2
2.469
2.875
.203
5.79
3
3.068
3.500
.216
7.58
31/2
3.548
4.000
.226
9.11
4
4.026
4.500
.237
10.79
5
5.047
5.563
.258
14.62
6
6.065
6.625
.280
18.97
8
7.981
8.625
.322
28.55
10
10.020
10.750
.365
40.48
12
11.938
12.750
.406
53.52
16
15.000
16.000
.500
82.77
18
16.876
18.000
.562
104.7
20
18.812
20.000
.594
123.1
24
22.624
24.000
.688
171.3
32
30.624
32.000
.688
230.1
34 | 32.624 | 34.000 | .688 | 244.77 |
36 | 34.500 | 36.000 | .750 | 282.35 |
42 | 40.500 | 42.000 | .750 | 330.00 |
Diameter
(Inches) |
Properties of Sections
Nominal
Inside
Outside
Moment |
Radius
of Gyration |
Section Modulus
(in3) |
1/8
.269
.405
.00106
.122
.00525
1/4
.364
.540
.00331
.163
.01227
3/8
.493
.675
.00729
.209
.02160
1/2 |
.622
.840
.01709
.261
.04070
3/4
.824
1.050
.03704
.334
.07055
1
1.049
1.315
.08734
.421
.1328
11/4
1.380
1.660
.1947
.539
.2346
1 1/2
1.610
1.900
.3099
.623
.3262
2
2.067
2.375
.6658
.787
.5607
21/2
2.469
2.875
1.530
.947
1.064
3
3.068
3.500
3.017
1.163
1.724
31/2
3.548
4.000
4.788
1.337
2.394
4
4.026
4.500
7.233
1.510
3.215
5
5.047
5.563
15.16
1.878
5.451
6
6.065
6.625
28.14
2.245
8.496
8
7.981
8.625
72.49
2.938
16.81
10
10.020
10.750
160.7
3.674
29.91
12
11.938
12.750
300.2
4.364
47.09
16
15.000
16.000
732.0
5.484
91.50
18
16.876
18.000
1172.0
6.168
130.2
20
18.812
20.000
1706.0
6.864
170.6
24
22.624
24.000
3426.0
8.246
285.5
32
30.624
32.000
8283.3
11.07
518.7
34 | 32.624 | 34.000 | 9991.6 | 11.78 | 587.7 |
36 | 34.500 | 36.000 | 12906.1 | 12.466 | 717.0 |
42 | 40.500 | 42.000 | 20689 | 14.59 | 985.2 |
