Related Resources: fluid flow
Wet Bulb Temperature Equation
The wet-bulb temperature, Twet, is a common humidity variable (e.g., Schwerdtfeger 1976, p 50ff.). A wetted thermometer will read lower than the ambient air temperature because of evaporation (but higher with condensation), and that rate of evaporation depends on the mixing ratio. At equilibrium, a wellventilated wet-bulb thermometer obeys (Andreas 1995; Bohren and Albrecht 1998, p. 218ff).
(Eq 1)
where:
cp = specific heat of dry air at temperature Ta
Lv = latent heat of vaporization at Ta
r = ambient mixing ratio
rsat = saturation mixing ratio at the wet-bulb temperature.
Rearranging (Eq. 1) shows that the wet-bulb temperature predicts the mixing ratio,
(Eq 2)
And
(Eq 3)
e = Water vapor pressure
esat = Saturation pressure of water vapor
P = Barometric pressure
Ma = Molecular weight of air (= 28.9644 × 10-3 kg mol-1)
mw = Mass of pure water in a salt or fresh water sample
Ta = Air temperature
which is approximately
(Eq. 4)
That is, the wet-bulb temperature also predicts the vapor pressure. Table 1 shows the vapor pressure computed from (EQ. 4) for a range of Ta and Ta − Twet values.
Equations (Eq 2) and (Eq 4) apply to perfect wet-bulb thermometers. Schwerdtfeger (1976, p. 51f.) and Brock and Richardson (2001, p. 94) describe some second-order corrections that may be necessary to account for ventilation rate, radiative effects, and the size of the wet bulb.
Vapor pressure (e, in mb) from (Eq 4) as a function of the air temperature (Ta) and the wet-bulb depression for wet-bulb temperatures above freezing. The column with Ta − Twet = 0 is also the saturation vapor pressure (esat) at the indicated air temperature; consequently, the ratio of e at Ta − Twet > 0 to esat is the fractional relative humidity (f) at Ta − Twet. The barometric pressure P is assumed to be 1000 mb.
Wet-Bulb Depression, Ta − Twet (°C)
Table 1
Wet-Bulb Depression, Ta − Twet (°C) |
0.0 |
0.2 |
0.4 |
0.6 |
0.8 |
1.0 |
1.5 |
2.0 |
3.0 |
4.0 |
5.0 |
6.0 |
8.0 |
10.0 |
Ta (°C) |
0 |
6.1 |
2 |
7.1 |
6.9 |
6.6 |
6.4 |
6.2 |
6.0 |
5.4 |
4.8 |
4 |
8.2 |
7.9 |
7.7 |
7.4 |
7.2 |
7.0 |
6.4 |
5.8 |
4.7 |
3.5 |
6 |
9.4 |
9.1 |
8.9 |
8.6 |
8.4 |
8.1 |
7.5 |
6.9 |
5.7 |
4.5 |
3.3 |
2.2 |
8 |
10.8 |
10.5 |
10.2 |
9.9 |
9.7 |
9.4 |
8.7 |
8.1 |
6.8 |
5.6 |
4.4 |
3.2 |
0.9 |
10 |
12.3 |
12.0 |
11.7 |
11.4 |
11.2 |
10.9 |
10.2 |
9.5 |
8.1 |
6.8 |
5.5 |
4.3 |
1.9 |
12 |
14.1 |
13.8 |
13.5 |
13.1 |
12.8 |
12.5 |
11.8 |
11.0 |
9.6 |
8.2 |
6.8 |
5.5 |
2.9 |
0.5 |
14 |
16.0 |
15.7 |
15.4 |
15.0 |
14.7 |
14.4 |
13.6 |
12.8 |
11.2 |
9.7 |
8.2 |
6.8 |
4.1 |
1.6 |
16 |
18.3 |
17.9 |
17.5 |
17.2 |
16.8 |
16.5 |
15.6 |
14.7 |
13.1 |
11.5 |
9.9 |
8.4 |
5.5 |
2.8 |
18 |
20.7 |
20.3 |
19.9 |
19.6 |
19.2 |
18.8 |
17.9 |
16.9 |
15.1 |
13.4 |
11.7 |
10.1 |
7.1 |
4.2 |
20 |
23.5 |
23.0 |
22.6 |
22.2 |
21.8 |
21.4 |
20.4 |
19.4 |
17.5 |
15.6 |
13.8 |
12.1 |
8.8 |
5.7 |
22 |
26.5 |
26.1 |
25.6 |
25.2 |
24.7 |
24.3 |
23.2 |
22.1 |
20.1 |
18.1 |
16.1 |
14.3 |
10.8 |
7.5 |
24 |
30.0 |
29.5 |
29.0 |
28.5 |
28.0 |
27.5 |
26.4 |
25.2 |
23.0 |
20.8 |
18.7 |
16.7 |
13.0 |
9.4 |
26 |
33.7 |
33.2 |
32.7 |
32.2 |
31.7 |
31.1 |
29.9 |
28.6 |
26.2 |
23.9 |
21.6 |
19.5 |
15.4 |
11.6 |
28 |
38.0 |
37.4 |
36.8 |
36.2 |
35.7 |
35.1 |
33.8 |
32.4 |
29.8 |
27.3 |
24.9 |
22.6 |
18.2 |
14.1 |
30 |
42.6 |
42.0 |
41.4 |
40.8 |
40.2 |
39.6 |
38.1 |
36.6 |
33.8 |
31.1 |
28.5 |
26.0 |
21.2 |
16.8 |
32 |
47.8 |
47.1 |
46.4 |
45.8 |
45.1 |
44.5 |
42.9 |
41.3 |
38.2 |
35.3 |
32.5 |
29.7 |
24.6 |
19.9 |
34 |
53.4 |
52.7 |
52.0 |
51.3 |
50.6 |
49.9 |
48.1 |
46.4 |
43.1 |
39.9 |
36.9 |
33.9 |
28.4 |
23.3 |
36 |
59.7 |
58.9 |
58.1 |
57.4 |
56.6 |
55.8 |
53.9 |
52.1 |
48.5 |
45.1 |
41.8 |
38.6 |
32.6 |
27.1 |
38 |
66.6 |
65.7 |
64.9 |
64.0 |
63.2 |
62.4 |
60.4 |
58.4 |
54.5 |
50.8 |
47.2 |
43.7 |
37.2 |
31.2 |
40 |
74.1 |
73.2 |
72.3 |
71.4 |
70.5 |
69.6 |
67.4 |
65.2 |
61.0 |
57.0 |
53.1 |
49.4 |
42.4 |
35.9 |
