Steady State Conduction Multilayer Isothermal Walls Formulas and Calculator
The following equation will calculate the temperature on one side of an isothermal constant temperature multilayered plate or wall. The heat load (q) conducted through the layers as well as the temperature on one side of the plate (T1) are required as well. For each layer the layer thickness (ti) as well as the layer conductivity ki must be defined.
Preview: Steady State Conduction Multilayer Isothermal Walls Calculator
The temperature Tn is calculated as:
or
Tn = Temperature oC
T1 = Known surface temperature oC
q = Heat flow (positive heat flow is from T1 to Tn)
ti = Thickness of each layer i (M)
ki = Thermal conductivity of layer i (W/m-oC)
HD = Surface area (H x D) the plate being considered M2
End surfaces of the plate are assumed adiabatic.
Positive values of heat (q) result in Tn being hotter than T1. Negative values of heat (q) result in Tn being cooler than T1.
