Conductive Heat Transfer Cylinder of Length Equation and Calculator
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Conductive Heat Transfer of Circular isothermal cylinder of length L in the midplane of an infinite wall (z > 0.5D)
Preview: Conductive Heat Transfer Cylinder of Length Calculator
T1 = Temperature (°C)
T2 = Temperature (°C)
D = Diameter (m)
L = Length (m)
z = Depth/Distance (m)
