Conductive Heat Transfer of a Disk Equation and Calculator
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Conductive Heat Transfer of a Disk buried parallel to the surface in a semi-infinite medium (z >> D)
Preview: Conductive Heat Transfer of a Disk Calculator
T1 = Temperature (°C)
T2 = Temperature (°C)
D = Diameter (m)
z = Distance (m)
