Conductive Heat Transfer Parallel Cylinders Equation and Calculator
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Conductive Heat Transfer of A row of equally spaced parallel isothermal cylinders buried in a semi-infinite medium (L >>D, z and w >1.5D)
Preview: Two Cylinders at Known Separation Calculator
Per cylinder
T1 = Temperature (°C)
T2 = Temperature (°C)
D = Diameter (m)
L = Length (m)
w = Separation Distance (m)
z = Depth/Distance (m)
