Conductive Heat Transfer Sphere Buried Insulated Equation and Calculator
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Conductive Heat Transfer of a Isothermal sphere buried in a semi-infinite medium at T2 whose surface is insulated
Preview: Conductive Heat Transfer Sphere Buried Insulated Calculator
T1 = Temperature (°C)
T2 = Temperature (°C)
z = Distance (m)
D = Diameter (m)
