Cylinder Heat Transfer Buried in Medium Equation and Calculator
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Heat Loss of cylinder buried in a semi-infinite medium equation and calculator.
Vertical isothermal cylinder of length L buried in a semi-infinite medium (L >>D)
Preview: Cylinder Buried in a Semi-Infinite Medium Calculator
T1 = Temperature (°C)
T2 = Temperature (°C)
D = Diameter (m)
L = Length (m)
