Fuel Gas and Heating Values
Types of Fuel Gas and Heating Values
Natural gas, LPG, and propane are commonly used fuel gases. LPG is a mixture of propane and butane. It is generally transported and stored in liquid form. Other gases may also be used as fuel, but cost and availability may dictate the use of a specific gas over another. Table 1 lists commonly available fuel gases and their properties such as heating value and density.
LPG is the commercial term for a liquid under pressure that contains varying proportions of propane (C3H8) and butane (C4H10). It is generally transported and stored as a liquid under pressure ranging from 200 to 300 pounds per square inch (lb/in2 or psi). As a liquid it is approximately half as heavy as water. When the pressure is reduced, LPG vaporizes to form a gas with a specific gravity of approximately 1.52 (air = 1.00).
Gas name |
Heating value |
Specific gravity |
Density, lb/ft3 |
Specific volume, ft3/lb |
Btu/ft3 |
Btu/lb |
Gross |
Net |
Gross |
Net |
Acetylene |
1,498 |
1,447 |
21,569 |
21,837 |
0.91 |
0.070 |
14.4 |
Blast furnace gas |
92 |
92 |
1,178 |
1,178 |
1.02 |
0.078 |
12.8 |
Butane |
3,225 |
2,977 |
21,640 |
19,976 |
1.95 |
0.149 |
6.71 |
Butylene |
3,077 |
2,876 |
20,780 |
19,420 |
1.94 |
0.148 |
6.74 |
Carbon monoxide |
323 |
323 |
4,368 |
4,368 |
0.97 |
0.074 |
13.5 |
Carbureted gas |
550 |
508 |
11,440 |
10,566 |
0.63 |
0.048 |
20.8 |
Coke oven gas |
574 |
514 |
17,048 |
15,266 |
0.44 |
0.034 |
29.7 |
Sewage gas |
690 |
621 |
11,316 |
10,184 |
0.80 |
0.062 |
16.3 |
Ethane |
1,783 |
1,630 |
22,198 |
20,295 |
1.06 |
0.060 |
12.5 |
Hydrogen |
325 |
275 |
61,084 |
51,628 |
0.07 |
0.0054 |
186.9 |
Methane |
1,011 |
910 |
23,811 |
21,433 |
0.55 |
0.042 |
23.8 |
Natural gas, |
1,073 |
971 |
20,065 |
18,158 |
0.70 |
0.054 |
18.4 |
California, U.S. |
Propane |
2,572 |
2,365 |
21,500 |
19,770 |
1.52 |
0.116 |
8.61 |
Propylene |
2,332 |
2,181 |
20,990 |
19,630 |
1.45 |
0.111 |
9.02 |
Water gas (bituminous) |
261 |
239 |
4,881 |
4,469 |
0.71 |
0.054 |
18.7 |
- Piping Calculations Manual,
E. Shashi Menon
SYSTEK Technologies, Inc
