Heat Transfer Coefficients U-Factor for Windows
Heat Transfer Engineering
Thermodynamics
Overall U-factors (heat transfer coefficients) for various windows and skylights in W / (m2 · °C) (from ASHRAE Handbook of Fundamentals, Ref. 1, Chap. 27, Table 5)
Aluminum frame
Glass section (glazing) only
(without thermal break)
Wood or vinyl frame
Type
Center
of
glass
Edge
of
glass
Fixed
Double door
Sloped
skylight
Fixed
Double door
Sloped
skylight
Frame width
(Not applicable)
32 mm
(1 1/4)
53 mm
(2 in.)
19 mm
(3/4 in.)
41 mm
(1 5/8 in.)
88 mm
(3 7/18 in.)
23 mm
(7/8 in.)
Spacer type
Metal
Insul.
All
All
All
Metal
Insul.
Metal
Insul.
Metal
Insul.
Glazing Type
Single Glazing
3 mm (1/8 in.) Glass
6.30
6.30
6.63
7.16
9.88
5.93
5.57
5.57
7.57
6.4 mm (1/4 in.) acrylic
5.28
5.28
5.69
6.27
8.86
5.02
4.77
6.57
3 mm (1/8 in.) acrylic
5.79
5.79
6.16
6.71
9.94
5.48
5.17
7.63
Double Glazing (no coating)
6.4 mm air space
3.24
3.71
3.34
3.90
4.55
6.7
3.26
3.16
3.20
3.09
4.37
4.22
12.7 mm air space
2.78
3.40
2.91
3.51
4.18
6.65
2.88
2.76
2.86
2.74
4.32
4.17
6.4 mm argon space
2.95
3.52
3.07
3.66
47.32
6.47
3.03
2.91
2.98
2.87
4.14
3.97
12.7 mm argon space
2.61
3.28
2.76
3.36
4.04
6.47
2.74
2.61
2.73
2.60
4.14
3.97
Double Glazing [ ε = 0.1, coating on one of the surfaces of air space (surface 2 or 3, counting from the outside toward inside)]
6.4 mm air space
2.44
3.16
2.60
3.21
3.89
6.04
2.59
2.46
2.60
2.47
3.73
3.53
12.7 mm air space
1.82
2.71
2.06
2.67
3.37
6.04
2.06
1.92
2.13
1.99
3.73
3.53
6.4 mm argon space
1.99
2.83
2.21
2.82
3.52
5.62
2.21
2.07
2.26
2.12
3.32
3.09
12.7 mm argon space
14.53
2.49
1.83
2.42
3.14
5.71
1.82
1.67
1.91
1.78
3.41
3.19
Triple Glazing (no coating)
6.4 mm air space
2.16
2.96
2.35
2.97
3.66
5.81
2.34
2.18
2.36
2.21
3.48
3.24
12.7 mm air space
1.76
2.67
2.02
2.62
3.33
5.67
2.01
1.84
2.07
1.19
3.34
3.09
6.4 mm argon space
1.93
2.79
2.16
2.77
3.47
5.57
2.15
1.99
2.19
2.04
3.25
3.00
12.7 mm argon space
1.65
2.58
1.92
2.52
3.23
5.53
1.91
1.74
1.98
1.82
3.20
2.95
Triple Glazing [ ε = 0.1, coating on one of the surfaces of air spaces (surfaces 3 and 5, counting from the outside toward inside)]
6.4 mm air space
1.53
2.49
1.83
2.42
3.14
5.24
1.81
1.64
1.89
1.73
2.92
2.66
12.7 mm air space
0.97
2.05
1.38
1.92
2.66
5.10
1.33
1.15
1.46
1.30
2.78
2.52
6.4 mm argon space
1.19
2.23
1.56
2.12
2.85
4.90
1.52
1.35
1.64
1.47
2.59
2.33
12.7 mm argon space
0.80
1.92
1.25
1.77
2.51
4.86
1.18
1.01
1.33
1.17
2.55
2.28
Notes:
(1) Multiply by 0.176 to obtain U-factors in Btu/h · ft2 · °F.
(2) The U-factors in this table include the effects of surface heat transfer coefficients and are based on winter conditions of -18°C outdoor air and 21°C indoor air temperature, with 24 km/h (15 mph) winds outdoors and zero solar flux. Small changes in indoor and outdoor temperatures will not affect the overall U-factors much. Windows are assumed to be vertical, and the skylights are tilted 20° from the horizontal with upward heat flow. Insulation spacers are wood, fiberglass, or butyl. Edge-of-glass effects are assumed to extend the 65-mm band around perimeter of each glazing. The product sizes are 1.2 m x 1.8 m for fixed windows, 1.8 m x 2.0 m for double-door windows, and 1.2 m x 0.6 1 8m for the skylights, but the values given can also be used for products of similar sizes. All data are based on 3-mm ( 1/8 -in.) glass unless noted otherwise.
