Insulating Materials Thermal Properties
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Thermal Properties of insulating materials (at a mean temperature of 24°C)
Material |
Thermal Thickness, L mm |
Density, ρ kg/m3 |
Conductivity, k W/m·K |
Specific Heat, cp kJ/kg·K |
R-value (for listed thickness, L/k), K·m2/W |
Blanket and Batt |
Mineral fiber (fibrous form processed from rock, slag,or glass) |
50 to 70 mm |
4.8–32 |
0.71–0.96 |
1.23 |
75 to 90 mm |
4.8–32 |
0.71–0.96 |
1.94 |
135 to 165 mm |
4.8–32 |
0.71–0.96 |
3.32 |
Board and Slab |
Cellular glass |
136 |
0.055 |
1.0 |
Glass fiber (organic bonded) |
64–144 |
0.036 |
0.96 |
Expanded polystyrene (molded beads) |
16 |
0.040 |
1.2 |
Expanded polyurethane (R-11 expanded) |
24 |
0.023 |
1.6 |
Expanded perlite (organic bonded) |
16 |
0.052 |
1.26 |
Expanded rubber (rigid) |
72 |
0.032 |
1.68 |
Mineral fiber with resin binder |
240 |
0.042 |
0.71 |
Cork |
120 |
0.039 |
1.80 |
Sprayed or Formed in Place |
Polyurethane foam |
24–40 |
0.023–0.026 |
Glass fiber |
56–72 |
0.038–0.039 |
Urethane, two-part mixture (rigid foam) |
70 |
0.026 |
1.045 |
Mineral wool granules with asbestos/ |
inorganic binders (sprayed) |
190 |
0.046 |
Loose Fill |
Mineral fiber (rock, slag, or glass) |
~75 to 125 mm |
9.6–32 |
0.71 |
1.94 |
~165 to 222 mm |
9.6–32 |
0.71 |
3.35 |
~191 to 254 mm |
0.71 |
3.87 |
~185 mm |
0.71 |
5.28 |
Silica aerogel |
122 |
0.025 |
Vermiculite (expanded) |
122 |
0.068 |
Perlite, expanded |
32–66 |
0.039–0.045 |
1.09 |
Sawdust or shavings |
128–240 |
0.065 |
1.38 |
Cellulosic insulation (milled paper or wood pulp) |
37–51 |
0.039–0.046 |
Roof Insulation |
Cellular glass |
144 |
0.058 |
1.0 |
Preformed, for use above deck |
13 mm |
1.0 |
0.24 |
25 mm |
2.1 |
0.49 |
50 mm |
3.9 |
0.93 |
Reflective Insulation |
Silica powder (evacuated) |
160 |
0.0017 |
Aluminum foil separating fluffy glass mats; 10–12 layers |
(evacuated); for cryogenic applications (150 K) |
40 |
0.00016 |
Aluminum foil and glass paper laminate; 75–150 |
layers (evacuated); for cryogenic applications (150 K) |
120 |
0.000017 |
