Linear Thermal Expansion Equation and Calculator
Heat Transfer Engineering
Thermodynamics
Linear Section Thermal Expansion Equation and Calculator
Linear expansion is the change in length as opposed to change in volume. To a first approximation, the change in length measurements of an object due to thermal expansion is related to temperature change by a "linear expansion coefficient". It is the change in length per degree of temperature change.
Preview: Calculator Change of Length
ΔL = α l0 ΔT
or
ΔT = ΔL / α l0
ΔT = End Temperature T1 - Start Temperature T2 (°F, °C)
ΔL = Change in length (in, m) or l1 - l0
l0 = Length (in, m)
l1 = Length (in, m)
α = Coefficient of Thermal Expansion (1/°F, 1/°C). Note: that units may be expressed as in / in-°F, m / m-°C
