Radiant Heat Exchange Plates Different Sizes Equation and Calculator
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Radiant heat exchange for two isothermal (constant temperature) parallel flat black plates of different sizes equation and calculator.
Heat Loss From an Insulated Electric Wire Equation and Calculator
Preview: Radiant heat exchange for two parallel flat black plates different size calculator
The heat flow (q) from the plate is calculated as:
q = 56.69 x 10-9 x VF(1-2) x L12 x (T14 - T24 )
Where 56.69 x 10-9 is the average Stefan-Bolzmann constant, L1is the area of the plate, T1 is the plate 1 temperature and T2 is the plate 2 temperature. The view factor VF(1-2) (also known as radiation shape factor, angle factor, and configuration factor) is defined as:
Length of plate 1 divided by the distance between the plates (L 1 / D) must be greater than 0.2 for this calculation.
x = (C) x ( 1 +E )
y = (C) x ( 1 - E )
C = L1 / D
D = L2 / L1
W = Plate Width (W)
D = Spacing (m)
T1 = Plate 1 Temperature (K)
T2 = Plate 2 Temperature (K)
VF1-2 = View Factor
q = Radiated Heat Flow (W)
References
Rosenow, W. M., J. P. Hartnett, Y. I. Young, Handbook of Heat Transfer , 3rd Ed., McGraw-Hill Handbooks, New York, 1998. p. 7.3 - 7.19, 7.81.
