Solar Radiation Incident on the Surface
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Hourly variation of solar radiation incident on various surfaces and the daily totals throughout the year at 40° latitude (from ASHRAE Handbook of Fundamentals, Ref. 1, Chap. 27, Table 15)
Solar radiation is radiant energy emitted by the sun, particularly electromagnetic energy. About half of the radiation is in the visible short-wave part of the electromagnetic spectrum. The other half is mostly in the near-infrared part, with some in the ultraviolet part of the spectrum
Solar Radiation Incident on the Surface,* W/m2 |
Solar Time |
Date |
Direction of Surface |
5 |
6 |
7 |
8 |
9 |
10 |
11 |
12 noon |
13 |
14 |
15 |
16 |
17 |
18 |
19 |
Daily Total |
Jan. | N NE E SE S SW W NW Horizontal Direct |
0 0 0 0 0 0 0 0 0 0 |
20 63 402 483 271 20 20 20 51 446 |
43 47 557 811 579 48 43 43 198 753 |
66 66 448 875 771 185 59 59 348 865 |
68 68 222 803 884 428 68 68 448 912 |
71 71 76 647 922 647 76 71 482 926 |
68 68 68 428 884 803 222 68 448 912 |
66 59 59 185 771 875 448 66 348 865 |
43 43 43 48 579 811 557 47 198 753 |
20 20 20 20 271 483 402 63 51 446 |
0 |
0 |
446 489 1863 4266 5897 4266 1863 489 2568 — |
Apr. | N NE E SE S SW W NW Horizontal Direct |
41 262 321 189 18 17 17 17 39 282 |
57 508 728 518 59 52 52 52 222 651 |
79 462 810 682 149 77 77 77 447 794 |
97 291 732 736 333 97 97 97 640 864 |
110 134 552 699 437 116 110 110 786 901 |
120 123 293 582 528 187 120 120 880 919 |
122 122 131 392 559 392 392 122 911 925 |
120 120 120 187 528 582 293 123 880 919 |
110 110 110 116 437 699 552 134 786 901 |
97 97 97 97 333 736 732 291 640 864 |
79 77 77 77 149 682 810 462 447 794 |
57 52 52 52 59 518 728 508 222 651 |
41 17 17 17 18 189 321 262 39 282 |
1117 2347 4006 4323 3536 4323 4006 2347 6938 — |
July | N NE E SE S SW W NW Horizontal Direct |
3 8 7 2 0 0 0 0 1 7 |
133 454 498 248 39 39 39 39 115 434 |
109 590 739 460 76 71 71 71 320 656 |
103 540 782 580 108 95 95 95 528 762 |
117 383 701 617 190 114 114 114 702 818 |
126 203 531 576 292 131 126 126 838 850 |
134 144 294 460 369 155 134 134 922 866 |
138 138 149 291 395 291 149 138 949 871 |
134 134 134 155 369 460 294 144 922 866 |
126 126 126 131 292 576 531 203 838 850 |
117 114 114 114 190 617 701 383 702 818 |
103 95 95 95 108 580 782 540 528 762 |
109 71 71 71 76 460 739 590 320 656 |
133 39 39 39 39 248 498 454 115 434 |
3 0 0 0 0 2 7 8 1 7 |
1621 3068 4313 3849 2552 3849 4313 3068 3902 — |
Oct. | N NE E SE S SW W NW Horizontal Direct |
0 |
7 74 163 152 44 7 7 7 14 152 |
40 178 626 680 321 40 40 40 156 643 |
62 84 652 853 547 66 62 62 351 811 |
77 80 505 864 711 137 87 87 509 884 |
87 87 256 770 813 364 87 87 608 917 |
90 90 97 599 847 599 97 90 640 927 |
87 87 87 364 813 770 256 87 608 917 |
77 87 87 137 711 864 505 80 509 884 |
62 62 62 66 547 853 652 84 351 811 |
40 40 40 40 321 680 626 178 156 643 |
7 7 7 7 44 152 163 74 14 152 |
453 869 2578 4543 5731 4543 2578 869 3917 — |
*Multiply by 0.3171 to convert to Btu/h · ft2. Values given are for the 21st of the month for average days with no clouds. The values can be up to 15 percent higher at high elevations under very clear skies and up to 30 percent lower at very humid locations with very dusty industrial atmospheres. Daily totals are obtained using Simpson’s rule for integration with 10-min time intervals. Solar reflectance of the ground is assumed to be 0.2, which is valid for old concrete, crushed rock, and bright green grass. For a specified location, use solar radiation data obtained for that location. The direction of a surface indicates the direction a vertical surface is facing. For example, W represents the solar radiation incident on a west-facing wall per unit area of the wall. Solar time may deviate from the local time. Solar noon at a location is the time when the sun is at the highest location (and thus when the shadows are shortest). Solar radiation data are symmetric about the solar noon: the value on a west wall before the solar noon is equal to the value on an east wall two hours after the solar noon.
