Specific Heat Capacity Table at Room Temperature
Heat Transfer and Engineering
HVAC Systems Components and Engineering
Specific heat capacity c is the change in heat (energy) of a unit mass of material for a unit change of temperature in Btu/lb·°F or Btu/(lbm-°R)
Substance | Mol wt |
cp |
cv |
k |
kJ/(kg·K) |
Btu/(lbm-°R) |
kJ/(kg⋅K) |
Btu/(lbm-°R) |
Specific Heat Capacity Gases | ||||||
Air |
29 |
1.00 |
0.240 |
0.718 |
0.171 |
1.40 |
Argon |
40 |
0.520 |
0.125 |
0.312 |
0.0756 |
1.67 |
Butane |
58 |
1.72 |
0.415 |
1.57 |
0.381 |
1.09 |
Carbon dioxide |
44 |
0.846 |
0.203 |
0.657 |
0.158 |
1.29 |
Carbon monoxide |
28 3 |
1.04 |
0.249 |
0.744 |
0.178 |
1.40 |
Ethane |
0 |
1.77 |
0.427 |
1.49 |
0.361 |
1.18 |
Helium |
4 |
5.19 |
1.25 |
3.12 |
0.753 |
1.67 |
Hydrogen |
2 |
14.3 |
3.43 |
10.2 |
2.44 |
1.40 |
Methane |
16 |
2.25 |
0.532 |
1.74 |
0.403 |
1.30 |
Neon |
20 |
1.03 |
0.246 |
0.618 |
0.148 |
1.67 |
Nitrogen |
28 |
1.04 |
0.248 |
0.743 |
0.177 |
1.40 |
Octane vapor |
114 |
1.71 |
0.409 |
1.64 |
0.392 |
1.04 |
Oxygen |
32 |
0.918 |
0.219 |
0.658 |
0.157 |
1.40 |
Propane |
44 |
1.68 |
0.407 |
1.49 |
0.362 |
1.12 |
Steam | 18 |
1.87 |
0.445 |
1.41 |
0.335 |
1.33 |
Substance | cp |
Density |
kJ/(kg·K) |
Btu/(lbm-°R) |
kg/m3 |
lbm/ft3 |
Specific Heat Capacity Liquids | ||||
Ammonia |
4.80 |
1.146 |
602 |
38 |
Mercury |
0.139 |
0.033 |
13,560 |
847 |
Water | 4.18 |
1.000 |
997 |
62.4 |
Specific Heat Capacity Solids | ||||
Aluminum |
0.900 |
0.215 |
2,700 |
170 |
Copper |
0.386 |
0.092 |
8,900 |
555 |
Ice (0°C; 32°F) |
2.11 |
0.502 |
917 |
57.2 |
Iron |
0.450 |
0.107 |
7,840 |
490 |
Lead | 0.128 |
0.030 |
11,310 |
705 |
- Specific Heat Capacity of Metals Table Chart
- Specific Heat Explained
- Specific Heat Common Gases at Various Temperatures
- Freezing Point and Properties of FoodsThe following is the Unfrozen Composition Data, Initial Freezing Point, and Specific Heats of Foods
- Heat Transfer, A Practical Approach - Heat transfer is a basic science that deals with the rate of transfer of thermal energy.
- Heat Loss or Gain From Pipe Excel Spreadsheet Calculator
- Heating Capacity of a Radiator Formula and Calculator
- Heat capacity of The Elements Table Chart
- Net Refrigeration Capacity Equations and Calculator
- Heat Radiating Capacity of a Steel Reservoir
- Specific Heat of Propylene Glycol
Source
NCEES Handbook - Fundamentals of Engineering Supplied-Reference Handbook, fifth Eition
