Thermal Conductivity of Gases Chart
This chart gives the thermal conductivity of gases as a function of temperature.
Unless otherwise noted, the values refer to a pressure of 100 kPa (1 bar) or to the saturation vapor pressure if that is less than 100 kPa.
The notation P = 0 indicates the low pressure limiting value is given. In general, the P = 0 and P = 100 kPa values differ by less than 1%.
Units: mW/m K ( milliwatts per meter kelvin).
MF |
Name |
100 K |
200 K |
300 K |
400 K |
500 K |
600 K |
Air |
9.4 |
18.4 |
26.2 |
33.3 |
39.7 |
45.7 |
Ar | Argon |
6.2 |
12.4 |
17.9 |
22.6 |
26.8 |
30.6 |
BF3 | Boron trifluoride |
19.0 |
24.6 |
H2 | Hydrogen (P = 0) |
68.6 |
131.7 |
186.9 |
230.4 |
F6S | Sulfur hexafluoride (P = 0) |
13.0 |
20.6 |
27.5 |
33.8 |
H2O | Water |
18.7 |
27.1 |
35.7 |
47.1 |
H2S | Hydrogen sulfide |
14.6 |
20.5 |
26.4 |
32.4 |
NH3 | Ammonia |
24.4 |
37.4 |
51.6 |
66.8 |
He | Helium (P = 0) |
75.5 |
119.3 |
156.7 |
190.6 |
222.3 |
252.4 8 |
Kr | Krypton (P = 0) |
3.3 |
6.4 |
9.5 |
12.3 |
14.8 |
17.1 |
NO | Nitric oxide |
17.8 |
25.9 |
33.1 |
39.6 |
46.2 |
N2 | Nitrogen |
9.8 |
18.7 |
26.0 |
32.3 |
38.3 |
44.0 |
N2O | Nitrous oxide |
9.8 |
17.4 |
26.0 |
34.1 |
41.8 |
Ne | Neon (P = 0) |
22.3 |
37.6 |
49.8 |
60.3 |
69.9 |
78.7 |
O2 | Oxygen |
9.3 |
18.4 |
26.3 |
33.7 |
41.0 |
48.1 |
O2S | Sulfur dioxide |
9.6 |
14.3 |
20.0 |
25.6 |
Xe | Xenon (P = 0) |
2.0 |
3.6 |
5.5 |
7.3 |
8.9 |
10.4 |
CCl2F2 | Dichlorodifluoromethane |
9.9 |
15.0 |
20.1 |
25.2 |
CF4 | Tetrafluoromethane (P = 0) |
16.0 |
24.1 |
32.2 |
39.9 |
CO |
Carbon monoxide (P = 0) |
25.0 |
32.3 |
39.2 |
45.7 |
CO2 | Carbon dioxide |
9.6 |
16.8 |
25.1 |
33.5 |
41.6 |
CHCl3 |
Trichloromethane |
7.5 |
11.1 |
15.1 |
CH4 | Methane |
22.5 |
34.1 |
49.1 |
66.5 |
84.1 |
CH4O |
Methanol |
26.2 |
38.6 |
53.0 |
C2H2 |
Acetylene |
21.4 |
33.3 |
45.4 |
56.8 |
C2H4 | Ethylene |
11.1 |
20.5 |
34.6 |
49.9 |
68.6 |
C2H6 |
Ethane |
11.0 |
21.3 |
35.4 |
52.2 |
70.5 |
C2H6O |
Ethanol |
14.4 |
25.8 |
38.4 |
53.2 |
C3H6O | Acetone |
11.5 |
20.2 |
30.6 |
42.7 |
C3H8 |
Propane |
18.0 |
30.6 |
45.5 |
61.9 |
C4H10 | Butane |
16.4 |
28.4 |
43.0 |
59.1 |
C5H12 | Pentane |
14.4 |
24.9 |
37.8 |
52.7 |
C6H14 |
Hexane |
23.4 |
35.4 |
48.7 |
Gases - Thermal Properties of Gases
Properties of Gases at Atmospheric Pressure
Gas | Temperature °C |
Conductivity W/m-°C |
Density kg/m3 |
Specific Heat J/kg-°C |
Dynamic Viscosity kg/m-s |
Kinematic Viscosity m2 /s |
Thermal Diffusivity m2 /s |
Helium | -129.0 |
0.0928 |
0.3379 |
5.2 x 103 |
12.55 x 10-6 |
37.11 x 10-6 |
52.75 x 10-6 |
Helium | -73.0 |
0.1177 |
0.2435 |
5.2 x 103 |
15.66 x 10-6 |
64.38 x 10-6 |
92.88 x 10-6 |
Helium | -18.0 |
0.1357 |
0.1906 |
5.2 x 103 |
18.17 x 10-6 |
95.5 x 10-6 |
136.75 x 10-6 |
Helium | 93.0 |
0.1691 |
0.1328 |
5.2 x 103 |
23.05 x 10-6 |
173.6 x 10-6 |
244.9 x 10-6 |
Helium | 204.0 |
0.197 |
0.10204 |
5.2 x 103 |
27.5 x 10-6 |
269.3 x 10-6 |
371.6 x 10-6 |
Helium | 316.0 |
0.225 |
0.08282 |
5.2 x 103 |
31.13 x 10-6 |
375.8 x 10-6 |
521.5 x 10-6 |
Helium | 427.0 |
0.251 |
0.07032 |
5.2 x 103 |
34.75 x 10-6 |
494.2 x 10-6 |
666.1 x 10-6 |
Helium | 527.0 |
0.275 |
0.06023 |
5.2 x 103 |
38.17 x 10-6 |
634.1 x 10-6 |
877.4 x 10-6 |
Hydrogen | -123.0 |
0.0981 |
0.16371 |
12.602 x 103 |
5.595 x 10-6 |
34.18 x 10-6 |
47.5 x 10-6 |
Hydrogen | -73.0 |
0.1282 |
0.1227 |
13.54 x 103 |
6.813 x 10-6 |
55.53 x 10-6 |
77.2 x 10-6 |
Hydrogen | -23.0 |
0.1561 |
0.09819 |
14.059 x 103 |
7.919 x 10-6 |
80.64 x 10-6 |
113.0 x 10-6 |
Hydrogen | 27.0 |
0.182 |
0.08185 |
14.314 x 103 |
8.963 x 10-6 |
109.5 x 10-6 |
155.4 x 10-6 |
Hydrogen | 77.0 |
0.206 |
0.07016 |
14.436 x 103 |
9.954 x 10-6 |
141.9 x 10-6 |
203.1 x 10-6 |
Hydrogen | 127.0 |
0.228 |
0.06135 |
14.491 x 103 |
10.864 x 10-6 |
177.1 x 10-6 |
256.8 x 10-6 |
Hydrogen | 177.0 |
0.251 |
0.05462 |
14.499 x 103 |
11.779 x 10-6 |
215.6 x 10-6 |
316.4 x 10-6 |
Hydrogen | 227.0 |
0.272 |
0.04918 |
14.507 x 103 |
12.636 x 10-6 |
257.0 x 10-6 |
381.7 x 10-6 |
Hydrogen | 277.0 |
0.292 |
0.04469 |
14.532 x 103 |
13.475 x 10-6 |
301.6 x 10-6 |
451.6 x 10-6 |
Hydrogen | 327.0 |
0.315 |
0.04085 |
14.537 x 103 |
14.285 x 10-6 |
349.7 x 10-6 |
530.6 x 10-6 |
Hydrogen | 427.0 |
0.351 |
0.03492 |
14.574 x 103 |
15.89 x 10-6 |
455.1 x 10-6 |
690.3 x 10-6 |
Hydrogen | 527.0 |
0.384 |
0.0306 |
14.675 x 103 |
17.4 x 10-6 |
569.0 x 10-6 |
856.3 x 10-6 |
Hydrogen | 527.0 |
0.412 |
0.02723 |
14.821 x 103 |
18.78 x 10-6 |
690.0 x 10-6 |
0.0010217 |
Oxygen | -123.0 |
0.01367 |
2.619 |
917.8 |
11.49 x 10-6 |
4.387 x 10-6 |
5.688 x 10-6 |
Oxygen | -73.0 |
0.01824 |
1.9559 |
913.1 |
14.85 x 10-6 |
7.593 x 10-6 |
10.214 x 10-6 |
Oxygen | -23.0 |
0.02259 |
1.5618 |
915.7 |
17.87 x 10-6 |
11.45 x 10-6 |
15.794 x 10-6 |
Oxygen | 27.0 |
0.02676 |
1.3007 |
920.3 |
20.63 x 10-6 |
15.86 x 10-6 |
22.353 x 10-6 |
Oxygen | 77.0 |
0.0307 |
1.1133 |
929.1 |
23.16 x 10-6 |
20.8 x 10-6 |
29.68 x 10-6 |
Oxygen | 127.0 |
0.03461 |
0.9755 |
942.0 |
25.54 x 10-6 |
26.18 x 10-6 |
37.68 x 10-6 |
Oxygen | 177.0 |
0.03828 |
0.8682 |
956.7 |
27.77 x 10-6 |
31.99 x 10-6 |
46.09 x 10-6 |
Oxygen | 227.0 |
0.04173 |
0.7801 |
972.2 |
29.91 x 10-6 |
38.34 x 10-6 |
55.02 x 10-6 |
Oxygen | 277.0 |
0.04517 |
0.7096 |
988.1 |
31.97 x 10-6 |
45.05 x 10-6 |
64.1 x 10-6 |
Nitrogen | -73.0 |
0.01824 |
1.7108 |
1.0429 x 103 |
12.947 x 10-6 |
7.568 x 10-6 |
10.224 x 10-6 |
Nitrogen | 27.0 |
0.0262 |
1.1421 |
1.0408 x 103 |
17.84 x 10-6 |
15.63 x 10-6 |
22.044 x 10-6 |
Nitrogen | 127.0 |
0.03335 |
0.8538 |
1.0459 x 103 |
21.98 x 10-6 |
25.74 x 10-6 |
37.34 x 10-6 |
Nitrogen | 227.0 |
0.03984 |
0.6824 |
1.0555 x 103 |
25.7 x 10-6 |
37.66 x 10-6 |
55.3 x 10-6 |
Nitrogen | 327.0 |
0.0458 |
0.5624 |
1.0756 x 103 |
29.11 x 10-6 |
51.19 x 10-6 |
74.86 x 10-6 |
Nitrogen | 427.0 |
0.05123 |
0.4934 |
1.0969 x 103 |
32.13 x 10-6 |
65.13 x 10-6 |
94.66 x 10-6 |
Nitrogen | 527.0 |
0.05609 |
0.4277 |
1.1225 x 103 |
34.84 x 10-6 |
81.46 x 10-6 |
116.85 x 10-6 |
Nitrogen | 627.0 |
0.0607 |
0.3796 |
1.1464 x 103 |
37.49 x 10-6 |
91.06 x 10-6 |
139.46 x 10-6 |
Nitrogen | 727.0 |
0.06475 |
0.3412 |
1.1677 x 103 |
40.0 x 10-6 |
117.2 x 10-6 |
162.5 x 10-6 |
Nitrogen | 827.0 |
0.0685 |
0.3108 |
1.1857 x 103 |
42.28 x 10-6 |
136.0 x 10-6 |
185.91 x 10-6 |
Nitrogen | 927.0 |
0.07184 |
0.2851 |
1.2037 x 103 |
44.5 x 10-6 |
156.1 x 10-6 |
209.32 x 10-6 |
Carbon dioxide | -53.0 |
0.010805 |
2.4733 |
783.0 |
11.105 x 10-6 |
4.49 x 10-6 |
5.92 x 10-6 |
Carbon dioxide | -23.0 |
0.012884 |
2.1657 |
804.0 |
12.59 x 10-6 |
5.813 x 10-6 |
7.401 x 10-6 |
Carbon dioxide | 27.0 |
0.016572 |
1.7973 |
871.0 |
14.958 x 10-6 |
8.321 x 10-6 |
10.588 x 10-6 |
Carbon dioxide | 77.0 |
0.02047 |
1.5362 |
900.0 |
17.205 x 10-6 |
11.19 x 10-6 |
14.808 x 10-6 |
Carbon dioxide | 127.0 |
0.02461 |
1.3424 |
942.0 |
19.32 x 10-6 |
14.39 x 10-6 |
19.463 x 10-6 |
Carbon dioxide | 177.0 |
0.02897 |
1.1918 |
980.0 |
21.34 x 10-6 |
17.9 x 10-6 |
24.813 x 10-6 |
Carbon dioxide | 227.0 |
0.03352 |
1.0732 |
1.013 x 103 |
23.26 x 10-6 |
21.67 x 10-6 |
30.84 x 10-6 |
Carbon dioxide | 277.0 |
0.03821 |
0.9739 |
1.047 x 103 |
25.08 x 10-6 |
25.74 x 10-6 |
37.5 x 10-6 |
Carbon dioxide | 327.0 |
0.04311 |
0.8938 |
1.076 x 103 |
26.83 x 10-6 |
30.02 x 10-6 |
44.83 x 10-6 |
Ammonia, NH 3 | 0.0 |
0.022 |
0.7929 |
2.177 x 103 |
9.353 x 10-6 |
11.8 x 10-6 |
13.08 x 10-6 |
Ammonia, NH 3 | 50.0 |
0.027 |
0.6487 |
2.177 x 103 |
11.035 x 10-6 |
17.0 x 10-6 |
19.2 x 10-6 |
Ammonia, NH 3 | 100.0 |
0.0327 |
0.559 |
2.236 x 103 |
12.886 x 10-6 |
23.0 x 10-6 |
26.19 x 10-6 |
Ammonia, NH 3 | 150.0 |
0.0391 |
0.4934 |
2.315 x 103 |
14.672 x 10-6 |
29.7 x 10-6 |
34.32 x 10-6 |
Ammonia, NH 3 | 200.0 |
0.0467 |
0.4405 |
2.395 x 103 |
16.49 x 10-6 |
37.4 x 10-6 |
44.21 x 10-6 |
Water vapor | 107.0 |
0.0246 |
0.5863 |
2.06 x 103 |
12.71 x 10-6 |
21.6 x 10-6 |
20.36 x 10-6 |
Water vapor | 127.0 |
0.0261 |
0.5542 |
2.014 x 103 |
13.44 x 10-6 |
24.2 x 10-6 |
23.38 x 10-6 |
Water vapor | 177.0 |
0.0299 |
0.4942 |
1.98 x 103 |
15.25 x 10-6 |
31.1 x 10-6 |
30.7 x 10-6 |
Water vapor | 227.0 |
0.0339 |
0.4405 |
1.985 x 103 |
17.04 x 10-6 |
38.6 x 10-6 |
38.7 x 10-6 |
Water vapor | 277.0 |
0.0379 |
0.4005 |
1.997 x 103 |
18.84 x 10-6 |
47.0 x 10-6 |
47.5 x 10-6 |
Water vapor | 327.0 |
0.0422 |
0.3652 |
2.026 x 103 |
20.67 x 10-6 |
56.6 x 10-6 |
57.3 x 10-6 |
Water vapor | 377.0 |
0.0464 |
0.338 |
2.056 x 103 |
22.47 x 10-6 |
66.4 x 10-6 |
66.6 x 10-6 |
Water vapor | 427.0 |
0.0505 |
0.314 |
2.085 x 103 |
24.26 x 10-6 |
77.2 x 10-6 |
77.2 x 10-6 |
Water vapor | 477.0 |
0.0549 |
0.2931 |
2.119 x 103 |
26.04 x 10-6 |
88.8 x 10-6 |
88.3 x 10-6 |
Water vapor | 527.0 |
0.0592 |
0.2739 |
2.152 x 103 |
27.86 x 10-6 |
102.0 x 10-6 |
100.1 x 10-6 |
Water vapor | 577.0 |
0.0637 |
0.2579 |
2.186 x 103 |
29.69 x 10-6 |
115.2 x 10-6 |
113.0 x 10-6 |
- Kadoya, K. Matsunaga, N., and Nagashima, A., Viscosity and thermal conductivity of dry air in the gaseous phase, J. Phys. Chem. Ref. Data, 14, 947, 1985.
- Younglove, B. A. and Hanley, H. J. M., The viscosity and thermal conductivity coefficients of gaseous and liquid argon, J. Phys. Chem. Ref. Data, 15, 1323, 1986.
- Holland, P. M., Eaton, B. E., and Hanley, H. J. M., A correlation of the viscosity and thermal conductivity data of gaseous and liquid ethylene, J. Phys. Chem. Ref. Data, 12, 917, 1983.
