Bolt or Pin In Double Shear Equation and Calculator
Strength / Mechanics of Materials
Beam Deflection & Structural Analysis
Bolt or Pin In Double Shear Equation and Calculator. Keep units consistant when performing calculations.
Single Shear Equation and Calculator
Bolt or Pin Double Shear Stress
Applied Force F (N, lbs) =
Bolt/Pin Diameter d (mm, in) =
Plate Thickness t (mm, in) =
Plate Thickness t1 (mm, in) =
Ultimate (Yield Min.) Stress  (N/mm2, lbs/in2) =
Factor of Safety  =
Results
Section Area of Bolt/Pin (mm2, in2) =
Shear Stress ave Bolt/Pin (N/mm2, lbs/in2) =
Bearing Area Stress Bt (N/mm2, lbs/in2) =
Bearing Area Stress Bt1 (N/mm2, lbs/in2) =
Allowable Stress (N/mm2, lbs/in2) =
Shear Stress Equation Double Shear
Shear Stress Average = Applied Force / Area
or
Shear Stress ave.= F/(2 π r 2)
or
Shear Stress ave.= 4F/(2 π d 2)
Shear Stress ave = ( N/mm2, lbs/in2)
F = Applied Force (N, Lbs)
π = pi or (3.14157)
r = Radius (mm, in.)
d = Diameter (mm, in.)
Bearing Stress Equation
Bearing Area Stress for t Plate and Bolt/Pin
Bt = F / (2 t d)
Bearing Area Stress for Plates t1and Bolt/'Pin
Bt1= F / ( t1 d)
Bt = Bearing Area Stress Area ( N/mm2, lbs/in2)
Bt1= Bearing Area Stress Area ( N/mm2, lbs/in2)
F = Applied Force (N, lbs)
t = Thickness (mm, in)
d = Diameter (mm, in)
Factor of Safety
Factor of Safety = F.S = ultimate stress / allowable stress
Therefore:
allowable stress = ultimate stress / F.S.
