Convergent Divergent Nozzle Flow Velocity and Area Equation and Calculator
Hydraulic & Pneumatics
Convergent-Divergent Nozzle Flow Velocity and Area Equation and Calculator
Throat Velocity Equation:
Values of the index n and the critical pressure ratio r, for different fluids are given in the table below.
Throat Area Equation:
Critical Pressure Ratio Equation:
Nozzle Outlet Velocity Equation:
Nozzle Outlet Area Equation:
where:
p1 = Inlet pressure (N / m2, Pa)
v1 = Inlet specific volume (m3)
vc = Outlet specific volume (m3)
C2 = Outlet velocity (m/sec)
Cc = Throat velocity (m/sec)
r = pressure ratio = p1 / p2
rc = critical pressure ratio
A2 = outlet area (m2)
Ac = throat area (m2)
n = index of expansion
m = mass flow rate (kg/m2)
Fluid |
n
rc
Air (n = γ) |
1.40
0.528
Initially dry saturated steam |
1.135 |
0.577
Initially superheated steam |
1.30
0.546
