Mohr’s Circle for Plane Stress
Strength / Mechanics of Materials Table of Content
The equations for plane stress transformation have a graphical solution, called Mohr’s circle, which is convenient to use in engineering practice, including “back-of-the-envelope” calculations.
Mohr’s circle is plotted on a coordinate system:
as in the illustration below, with the center C of the circle always on the:
σ axis at Stress average mohr's circle
The positive τ axis is downward for convenience, to make θ on the element and the corresponding 2θ on the circle agree in sense (both counterclockwise here).
1. The center C of the circle is always on the σ axis, but it may move left and right in a dynamic loading situation. This should be considered in failure prevention.
2. The radius R of the circle is τmax, and it may change, even pulsate, in dynamic loading. This is also relevant in failure prevention.
3. Working back and forth between the rectangular element and the circle should be done carefully and consistently. An angle θ on the element should be represented by 2θ in the corresponding circle. If τ is positive downward for the circle, the sense of rotation is identical in the element and the circle.
Mohrs circle
4. The principal stresses σ1 and σ2 are on the σ axis (τ ).
5. The planes on which σ1 and σ2 act are oriented at 2θpfrom the planes of σx and σy (respectively) in the circle and at θp in the element.
6. The stresses on an arbitrary plane can be determined by theirσ and τ coordinates from the circle. These coordinates give magnitudes and signs of the stresses. The physical meaning of +τ vs. –τ regarding material response is normally not as distinct as +σ vs. –σ (tension vs. compression).
7. To plot the circle, either use the calculated center C coordinate and the radius R, or directly plot the stress coordinates for two mutually perpendicular planes and draw the circle through the two points (A and B in illustration above) which must be diametrically opposite on the circle.
Special Cases of Mohr’s Circles for Plane Stress
Uniaxial tension formula
Uniaxial Tension
Pure shear formula
Pure Shear
Pure Shear
Biaxial tension-compression:
(similar to the case of pure shear).
