Various Types of Adhesives Typical Mechanical Performance
Strength and Mechanics of Materials
Materials Chemicals and Adhesives
Typical Mechanical Performance of Various Types of Adhesives and their
By strict definition, an adhesive is any substance that fastens or bonds materials to be joined (adherends) by means of surface attachment. The bond durability depends on the strength of the adhesive to the substrate (adhesion) and the strength within the adhesive (cohesion). Besides bonding a joint, an adhesive may serve as a seal against foreign matter. When an adhesive performs both bonding and sealing functions, it is usually referred to as an adhesive sealant. Joining materials with adhesives offers significant benefits compared with mechanical methods of uniting two materials.
Adhesive Chemistry or Type |
Room Temperature Lap-Shear Strength |
Pel Strength Per Unit Width |
MPa |
psi |
kN/m |
lb/in |
Pressure-sensitive |
0.01 - 0.07 |
2 - 10 |
0.18 - 0.88 |
1 - 5 |
Starch-based |
0.07 - 0.7 |
10 - 100 |
0.18 - 0.88 |
1 - 5 |
Cellosics |
0.35 - 3.5 |
50 - 500 |
0.18 - 1.8 |
1 - 10 |
Rubber-based |
0.35 - 3.5 |
50 - 500 |
1.8 - 7 |
10 - 40 |
Formulated hot melt |
0.35 - 4.8 |
50 - 700 |
0.88 - 3.5 |
5 - 20 |
Synthetically designed hot melt |
0.7 - 6.9 |
100 - 1,000 |
0.88 - 3.5 |
5 - 20 |
PVAc emulsion (white glue) |
1.4 - 6.9 |
200 - 1,000 |
0.88 - 1.8 |
5 - 10 |
Cyanoacrylate |
6.9 - 13.8 |
1,000 - 2,000 |
0.18 - 3.5 |
1 - 20 |
Protein-based |
6.9 - 13.8 |
1,000 - 2,000 |
0.18 - 1.8 |
1 - 10 |
Anaerobic acrylic |
6.9 - 13.8 |
1,000 - 2,000 |
0.18 - 1.8 |
1 - 10 |
Urethane |
6.9 - 17.2 |
1,000 - 2,500 |
1.8 - 8.8 |
10 - 50 |
Rubber-modified acrylic |
13.8 - 24.1 |
2,000 - 3,500 |
1.8 - 8.8 |
10 - 50 |
Modified phenolic |
13.8 - 27.6 |
2,000 - 4,000 |
3.6 - 7 |
20 - 40 |
Unmodified epoxy |
10.3 - 27.6 |
1,500 - 4,000 |
0.35 - 1.8 |
2 - 10 |
Bis-maleimide |
13.8 - 27.6 |
2,000 - 4,000 |
1.8 - 3.5 |
1 - 20 |
Polyimide |
13.8 - 27.6 |
2,000 - 4,000 |
0.18 - 0.88 |
1 - 5 |
Rubber-modified epoxt |
20.7 - 41.4 |
3,000 - 6,000 |
4.4 - 14 |
25 - 80 |
- Budynas, Richard G., and J. Keith Nisbett, Shigley's Mechanical Engineering Design, 8th ed., New York: McGraw-Hill, 2008.
