Formulas International Tolerance (IT) Grades
Mechanical Tolerance Standards Menu
Formulas for Standard International Tolerance (IT) Grades per.ISO 286-1 1993 and ISO 919-1993
See: International Tolerance (IT) Grades Table
The IS0 system of limits and fits provides for 20 standard tolerance grades designated IT0l, IT0, ITl, , IT18 in the size range from 0 up to 500 mm (incl.), and 18 standard tolerance grades in the size range from 500 mm up to 3,150 mm (incl.), designated IT1 to IT18.
The values for standard tolerances for basic sizes from 500 mm up to 3 150 mm (incl.) were subsequently developed for experimental purposes, and since they have proved acceptable to industry they are now given as a part of the IS0 system.
Formula for standard tolerances in grades IT01, IT0 and IT1 for basic sizes up to and including 500 mm.
Standard Tolerance Grade |
Formula for calculation where D is the geometric mean of the basic size in millimeters |
IT01 |
0,3 + 0,008D |
IT0 |
0,5 + 0,012D |
IT1 |
0,8 + 0,020D |
Formula for Standard Tolerance Grade IT2. IT3 and IT4
None: The table values for tolerances in these grades have been approximately scaled in geometrical progression between the values for IT1 and IT5.
Formula for Standard Tolerance grade IT5 to IT18
The values for standard tolerances in grades IT5 to IT18 for basic sizes up to and including 500 mm are determined as a function of the standard tolerance factor, i.
i = 0,45 D1/3 + 0.001D
where D is the geometric mean of the basic size step in mm
D = (Low Range * High Range)(1/2)
This formula was empirically derived, being based on various national practices and on the premise that, for the same manufacturing process, the relationship between the magnitude of the manufacturing errors and the basic size approximates a parabolic function.
The values of the standard tolerances are calculated in terms of the standard tolerance factor, i, as shown in table below.
It should be noted that from IT6 upwards, the standard tolerances are multiplied by a factor of 10 at each fifth step. This rule applies to all standard tolerances and may be used to extrapolate values for IT grades above IT18.
Basic Size |
Standard Tolerance Grades |
IT1 |
IT2 |
IT3 |
IT4 |
IT5 |
1T6 |
1T7 |
1T8 |
1T9 |
Above |
Up to and including |
Formulae for standard tolerances (Results in micrometers) |
500 |
7 i |
10 i |
16 i |
25 i |
40i |
500 |
3,150 |
2 |
2,7 I |
3,7 I |
5 I |
7 I |
10 I |
16 I |
25 I |
40 I |
Basic
Size |
1T10
IT11
IT12
IT13
IT14
IT15
IT16
IT17
IT18
Above
Up to
and including |
500
64 i
100 i
160 i
250 i
400 i
640 i
1000 i
1600 i
2500 i
500
3,150
64 I
100 I
160 I
250 I
400 I
640 I
1000 I
1600 I
2500 I
Derivation of standard tolerances (IT) for basic sizes from 500 mm up to and including 3,150mm
The standard tolerance factor, I, in micrometers, is calculated from the following formula :
I = 0,004D + 2,1
where D is the geometric mean of the basic size step in millimeters
- Engineering, Manufacturing Tolerance Limits Fits Charts | ISO 286 Tolerances | Metric Tolerance
- Machinist Drilling Mechanical Tolerance Capabilities Chart - ANSI Size Drilled Hole Tolerance, ISO Metric Drill Sizes
- Design for Manufacturability and Assembly DFM DFMA Premium Resources
- Sheet Metal Design, Mechanical Tolerances and Overview
- Casting Tolerances per. NADCA and ISO
- Aluminum Extrusion Dimensions and Tolerances Specification
- ISO Tolerances For Bolt Fastener and Holes Table Chart ISO 286
ISO 286-1 1988
Current ISO standard has removed formulas
