Gauge Blocks Tolerances Specifications Table DIN 861
Table of tolerances for gauge blocks according to DIN 861, corresponds with ISO 3650 and SS 3348).
DIN 861 specifies the most important dimensional and quality characteristics of gauge blocks with a rectangular cross-section and a nominal length ln ranging from 0,5 to 1000 mm. The permissible deviations and tolerances are stated for four grades of accuracy, i.e. 00, 0, 1 and 2 and the calibration Grade K.
Nominal Legnth mm
Precision 00
Precision 0
Precision 1
Precision 2
Length
Tolerance (1) μm |
Max Length
Variation Width (2) μm |
Length
Tolerance (1) μm |
Max Length
Length
Tolerance (1) μm |
Max Length
Length
Tolerance (1) μm |
Max Length
-10
±0.06
0.05
±0.12
0.10
±0.20
0.16
±0.45
0.30
(10)-25
±0.07
0.05
±0.14
0.10
±0.30
0.16
±0.60
0.30
(25)-50
±0.10
0.06
±0.20
0.10
±0.40
0.18
±0.80
0.30
(50)-75
±0.12
0.06
±0.25
0.12
±0.50
0.18
±1.00
0.35
(75)-100
±0.14
0.07
±0.30
0.12
±0.60
0.20
±1.20
0.35
(100)-150
±0.20
0.08
±0.40
0.14
±0.80
0.20
±1.60
0.40
(150)-200
±0.25
0.09
±0.50
0.16
±1.00
0.25
±2.00
0.40
(200)-250
±0.30
0.10
±0.60
0.16
±1.20
0.25
±2.40
0.45
(250)-300
±0.35
0.10
±0.70
0.18
±1.40
0.25
±2.80
0.50
(300)-400
±0.45
0.12
±0.90
0.20
±1.80
0.30
±3.60
0.50
(400)-500
±0.50
0.14
±1.10
0.25
±2.20
0.35
±4.40
0.60
(500)-600
±0.60
0.16
±1.30
0.25
±2.60
0.40
±5.00
0.70
(600)-700
±0.70
0.18
±1.50
0.30
±3.00
0.45
±6.00
0.70
(700)-800
±0.80
0.20
±1.70
0.30
±3.40
0.50
±6.50
0.80
(800)-900
±0.90
0.20
±1.90
0.35
±3.80
0.50
±7.50
0.90
(900)-1000
±1.00
0.25
±2.00
0.40
±4.20
0.60
±8.00
1.50
1 = Permitted ±deviation at arbitrary point in relation to nominal dimension.
2 = Permitted length variation (depending on flatness and parallelism error).
Related Resources:
- Gauge Blocks Tolerances Specifications Table JIS B 7506
- Gauge Blocks Tolerances Specifications Table ASME B89.1.9
- Selection Gauge Blocks and Sine Bar
- How to Measure Screw Threads using Three Wire Method
- Dowel Pin Installation Design Tolerance Table Chart
- GD&T Geometric Dimensioning Tolerancing Basics Training
- GD&T Geometric Dimensioning Tolerancing Intermediate Training
- GDT ASME Y14.5-2009 Applications Training
- G&T Geometric Tolerancing ISO 1101 Training
- Online GD&T Fundamentals Training
