Metric Clearance Holes and Tolerances per. ASME B18.2.8-1999, R2010
Clearance Holes and Tolerances for Metric Size Fasteners per. ASME B18.2.8-1999, R2010
The recommended drill and hole sizes for metric fasteners are tabulated in this table calculator. The minimum recommended hole is the drill size and the maximum recommended hole size is based on standard tolerances. The hole sizes for metric fasteners are in agreement with ISO 273, Fasteners-Clearance Holes for Bolts and Screws, except that ISO 273 covers fastener sizes M1 through M150.
- Clearance Holes and Tolerances for Inch Size Fasteners
- Preferred Tolerance Limits Fits ANSI B4.1
- Cylindrical Fits and Tolerances Table for IP and Metric
- Preferred Tolerances Limits Fits Calculator RC - LTs
- Preferred Force Shrink Fits ANSI B4.1 Calculator
- Table of Hole Bore Tolerances per. ISO 286 Calculator
- Table of Shaft Tolerances per. ISO 286 Calculator
- Socket Head Installation & Design Tolerances
- Gage Tolerance Calculator ASME B89.1.5 Pin and Ring Gauges
- Ring gage and Master Disc Tolerances per B89.1.5
- Tolerance Calculator Fixed Fastener Condition
- Hole / Feature Pattern Plot
- Bearing Shaft and Housing Installation Tolerances Size and fit tolerances
- Standard Tolerances for Drop Forgings
- Thickness and Ejector Marks Tolerance Calculator Grade F Forgings
- Thickness of Wall and Ejector Marks Tolerance Calculator Grade E per. EN-10243-1 for Non-Circular Forgings
