Braking Torque Equation and Calculator
Mechanics And Machine Engineering and Design
Braking Torque Equation and Calculator:
Brake torque is the force applied at the brake wheel to stop the motion of the moving equipment.Assuming the operating conditions for the equipment are con- stant, a brake having a retarding torque equal to the full load torque of the motor to which it is applied is usually satisfactory.
Symbols used:
I = moment of inertia of a pair of wheels (kg-m2)
α = angular deceleration of wheels (m/sec2)
m = mass of vehicle (kg)
u = coefficient of friction between wheels and road (unitless)
g = gravity (m/sec2)
Tf = Torque (N-m)
Tbf = Torque Total Front (N-m)
Tbr = Torque Total Rear (N-m)
Preview: Braking Torque Calculator:
Braking Torque Basic Equation (Front wheels torque):
Rear wheel Torque:
Wheel Torque:
Deceleration
d = ug
Total Braking Torque for one wheel.
- Simple Band Brake Configuration #1 Force Equation and Calculator
- Simple Band Brake Configuration #2 Force Equation and Calculator.
- Differential Band Brake Configuration #1 Force Equation and Calculator
- Differential Band Brake Configuration #2 Force Equation and Calculator
- Band Brake Design Equations
- Differential Band Brake Design Equation
- Block Brake Design Equations
- Disk Brake Design Equations
- Internal Drum Shoe Brake Design Equations
