Clutch Disk Design Equations
Machine Design and Application
The simplest type of clutch is the single-plate clutch in which an annular plate with a surface of friction material is forced against a metal disk by means of a spring, or springs, or by other means. There are two theories which give slightly different values of torque capacity.
Uniform-wear theory equation
F = spring force
ro =outer radius of friction material
ri =inner radius of friction material
µ = coefficient of friction
Uniform-pressure theory equation
