Piston Slider Crank Mechanism Design Equations and Calculator
Preview: Piston Slider Crank Mechanism Design Calculator
Piston / Slider Crank Mechanism Design Equations
Displacement of Piston slider:
Angular velocity of connecting rod:
Linear velocity of piston slider:
Angular accerelation on connecting rod:
Piston Slider acceleration:
L = length of connecting rod (in, mm),
R = Radius of crank (in, mm),
X = distance from center of crankshaft A to wrist pin C (in, mm),
X′ = slider velocity (linear velocity of point C) (in/sec, mm/sec),
X″ = Slider acceleration (in/sec2, mm/sec2),
θ = crank angle measured from dead center when slider is fully extended (deg.),
φ = angular position of connecting rod; φ = 0 when θ = 0
φ′ = connecting rod angular velocity = dφ/dt (deg/sec),
φ″ = connecting rod angular acceleration = dφ/dt2 (deg/sec2),
ω = constant angular velocity of the crank (deg/sec)
Handbook of Machining and Metal Working Calculations, Ron A. Walsh 2001
