Large and Small Diameter Lifting Pulley / Drums Equation and Calculator
A simple pulley and drum may be used to lift a weight by applying a force with a rope which is wrapped about he outer diameter of one of the diameters.
Simple Pulley Lift
F : W = r : R
W = (F x R)/r
F x R = W x r
R = (W x r)/F
F = (F x R)/R
r = (F x R)/W
W = Unknown weight (lbs, N)
F = Applied force (lbs, N)
R = Radius large diameter (in, mm)
r = Radius small diameter (in, mm)
Pulley Lifting Calculator Force
Weight W (Lbs, N) =
Radius r (in, mm) =
Radius R (in, mm) =
Result
Force F (Lbs, N) =
Pulley Lifting Calculator Weight
Force F (Lbs, N) =
Radius r (in, mm) =
Radius R (in, mm) =
Result
Weight W (Lbs, N) =
Pulley Lifting Calculator Radius R
Weight W (Lbs, N) =
Radius r (in, mm) =
Force f (in, mm) =
Result
Radius R (in, mm) =
Pulley Lifting Calculator Radius r
Force F (Lbs, N) =
Radius R (in, mm) =
Weight W (in, mm) =
Result
Radius r (in, mm) =
