Steady-State Torque of a Coupling Equations
Power Transmission Knowledge Menu
Motor Generator Set Distributor
Steady-state torque (Ts) The torque used to select couplings should be based upon the following equations:
In SI units:
Steady-State Torque SI Units
In inch (imperial) units:
Steady-State Torque Imperial Units
TS = steady state torque used to select the coupling (SI, newton-meters; U.S., inch-pounds)
Pnormal = input power required by the driven machine at the specified normal operating point (SI, kilowatts; U.S., horsepower)
Nnormal = speed corresponding to the normal power (in revolutions per minute)
S.F. = service factor
