Circular Flat Head with Internal or External Pressure Equation and Calculator
Pressure Vessel Design and Engineering
Preview
Stress in Pressure Vessel Flanged or Dished Head Section Seam Calculator:
This equation applies when:
- When d does not exceed 24 in,
- th/d is not less than 0.05 or greater than 0.25,
- Head thickness, th is not less than the shell thickness, ts .
Required minimum wall thickness
t = d ( 0.13 P / ( S E) )0.5
P = Design pressure or max. allowable working pressure, psi
d = Inside diameter of vessel , inches
S = Rated stress value of the material
t = Minimum thickness of shell (wall) exclusive of corrosion, inches
th = Actual thickness used in actual design, inches
tr = Minimum required thickness of seamless shell for pressure, inches
ts = Actual thickness of shell, exclusive of corrosion allowance, inches
E = Weld Joint efficiency
