Cone Cylinder Own Weight Stress and Deflection Equation and Calculator
Cone Cylinder Stress and Deflection due to own weight at tangential top edge support Equation and Calculator. Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels.
Preview: Cone Cylinder Stress and Deflection due to own weight at tangential top edge Support Calculator
Cone Cylindrical |
Deflection and Stress by Own weight, δ force/unit volume tangential top edge support.
Meridional Stress
Circumferential Hoop Stress
Change in height dimension y
Where used:
v = Poisson's ratio
δ = Liquid density (lbs/in3)
σ1,2 = stress, (lbs/in2)
α = Angle (deg.)
