Cone Cylinder Stress and Deflection Equations and Calculator
Cone Cylinder Stress and Deflection Filled to Depth with Liquid Tangential Edge Support Equation and Calculator. Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels.
Preview: Cylinder Stress and Deflection Filled to Depth with Liquid Tangential Edge Support Calculator
Cone Cylindrical |
At any level y below the liquid surface y < d
Meridional Stress
Circumferential or Hoop Stress
Change in height dimension y
At any level y above the liquid level
Note: There is a discontinuity in the rate of increase in fluid pressure at the top of the liquid. This leads to some bending in this region and is indicated by a discrepancy in the two expressions for the meridional slope at y = d.)
Meridional Stress
σ2 = 0
Where used:
v = Poisson's ratio
δ = Liquid density (lbs/in3)
σ1,2 = stress, (lbs/in2)
y = At some level of the cone (in)
d = Liquid fill level, (in)
t = Wall thickness (in)
α = Angle (deg.)
