Cylinder Linearly Varying Radial Pressure Equation and Calculator
Cylinder Linearly Varying Radial Pressure Stress and Deflection Equation and Calculator.
Preview: Cylindrical Pressure Vessel Linearly Varying Radial Pressure Calculator
Cylindrical
Cylindrical
( R / t ) > 10
Linearly Varying
Radial Pressure
When:
R / t > 10
Meridional Stress
Meridional Stress
Circumferential or Hoop Stress
Change in height dimension y
Where used:
v = Poisson's ratio
σ1,2 = stress, (lbs/in2)
t = Cylinder thickness, (in)
l = Length of cylinder, (in)
y = Length of linearly increasing load, (in)
R = Radius, (in)
q = Applied unit load (lbs/in2)
qo = Peak applied unit load (lbs/in2)
