Smooth Figure of Revolution Stress and Deflection Equation and Calculator
Any smooth figure of revolution if R2 is less than infinity Uniform internal or external pressure, q force/unit area; tangential edge support Stress and Deflection Equation and Calculator.
Uniform internal or external pressure, q force / unit area; tangential edge support.
Preview: Smooth Figure of Revolution Stress and Deflection Calculator
Smooth Figure of |
Deflection and Stress Uniform loading, w force/unit area; on the horizontal projected area; tangential top edge support.
For R2 / t > 10
Meridional Stress
Circumferential Hoop Stress
Where used:
v = Poisson's ratio
q = Force applied (lbs/in)
σ1,2 = Stress, (lbs/in2)
R1 = Radius (in)
R2 = Radius (in)
t = Wall thickness (in)
θ = Angle (deg.)
