Spherical Cylinder Stress and Deflection Equations and Calculator
Spherical Cylinder Stress and Deflection Filled to depth d with liquid of density d force/unit volume; tangential edge support Equation and Calculator.
Preview: Spherical Cylinder Stress and Deflection Internal or External Pressure Calculator
Spherical Cylinder |
FIlled to
Depth ​With Liquid ![]() |
Deflection and Stress Filled to depth d with liquid of density d force/unit volume; tangential edge support .
For R2 / t > 10
At any level y below the liquid surface, y < d
Meridional Stress
Circumferential Hoop Stress
Change in height dimension y
Weight of liquid
Where used:
v = Poisson's ratio
δ = Density (lbs/in3)
σ1,2 = Stress, (lbs/in2)
R2 = Radius (in)
R = Distance as indicated (in)
y = Depth as indicated (in), Must be equal too or less than d
P = Force (lbs)
d = Depth of liquid (in)
t = Wall thickness (in)
θ = Angle (deg.)
(Note: There is a discontinuity in the rate of increase in fluid pressure at the top of the liquid. This leads to some bending in this region and is indicated by a discrepancy in the two expressions for the meridional slope at y = d.)
