Truncated Cone Cylinder Stress and Deflection Equations and Calculator
Truncated Cone Cylinder Stress and Deflection by Uniform loading on the horizontal projected area; tangential top edge support. Equation and Calculator.
Preview: Cone Cylinder Stress and Deflection by Uniform loading on the horizontal projected area Calculator
Truncated Cone Stress and Deflection
Deflection and Stress by Uniform loading on the horizontal projected area; tangential top edge support.
Meridional Stress
Meridional Stress
Circumferential Hoop Stress
Change in height dimension y
Where used:
v = Poisson's ratio
w = Applied force load (lbs/in2)
σ1,2 = stress, (lbs/in2)
R = Large radius (in)
α = Angle (deg.)
