Engineers Edge
Hydraulic & Pneumatic Torque Wrenches Application Review
Torque Design Menu
Hydraulic & Pneumatic Torque Wrenches are industrial torque tools used to install or remove fastener in applications requiring high torque or production performance. In most heavy industrial fastener applications, the requirement for applied high torque to nuts and bolts are due to:
  • Fatigue loading or installation requirements.
  • Removing challenging fasteners that have been torqued to high loads or have been exposed to corrosion or heavy loading conditions resulting in galling.
Technicians sometimes use breaker bars with extended length "cheater pipes" attached to remove or torque fasteners in these challenging situations. However, all industrial tools and technicians have their operating limits and can break or injure. In these “controlled torque” or "power torque" applications, industrial Hydraulic & Pneumatic Torque Wrenches are the logical solution. Other wise, technicians will likely strip threads, break bolt heads or even cause personal injury.
Hydraulic & Pneumatic Torque Wrenches are available in a variety of sizes, torque capabilities and custom applications for applying torque to virtually any type of fastener. Hydraulic & Pneumatic wrenches can be bulky and and laborious to operate. however, the fasteners these industrial tools are designed to operate on are also challenging to install or remove.
Hydraulic & Pneumatic torque tools can operate through the application of fluid pressure to a ram that extends and retracts, ratcheting the head. These specialized industrial torque wrenches are available i a wide variety of applied torque ranges, sizes and sensitivities.
www.engineersedge.com
Advertising | Contact
Privacy Policy
Applications and Design
Beam Deflections and Stress
Bearing Apps, Specs & Data
Belt Design Data Calcs
Civil Engineering
Design & Manufacturability
Electric Motor Alternators
Flat Plate Stress Calcs
Fluids Flow Engineering
Friction Engineering
Gears Design Engineering
General Design Engineering
Hardware, Imperial, Inch
Hardware, Metric, ISO
Heat Transfer
Hydraulics Pneumatics
HVAC Systems Calcs
Economics Engineering
Electronics Instrumentation
Engineering Mathematics
Engineering Standards
Finishing and Plating
Friction Formulas Apps
Lubrication Data Apps
Machine Design Apps
Manufacturing Processes
Materials and Specifications
Mechanical Tolerances Specs
Plastics Synthetics
Power Transmission Tech.
Pressure Vessel
Pumps Applications
Re-Bar Shapes Apps
Section Properties Apps
Strength of Materials
Spring Design Apps
Structural Shapes
Threads & Torque Calcs
Thermodynamics
Physics
Vibration Engineering
Videos Design Manufacture
Volume of Solids Calculators
Welding Stress Calculations
