Plastic Snap Fit Tapered Arm Dynamic Strain Equation Calculator
Plastics Design and Engineering Resources
Open: Snap Fit Tapered Arm Design Calculator The following are definitions for the elements:This calculator calculates the Dynamic Strain of a tapered cantilevered flexing finger typically used in plastic snap fit type designs.
ALL calculators require a Premium Membership The following are definitions for the elements:Y =[ 2 ε L2 ] / [ 3 ho] Where: ε = Dynamic Strain (in/in, mm/mm) Check calculated strain against material mechanical specifications. K = hL / ho CHART Proportioned Constant K Open: Snap Fit Tapered Arm Design Equation and Calculator
Link to this Webpage: © Copyright 2000 -
2024, by Engineers Edge, LLC |
