Rectangle Structural Tube Per. ASTM 1085 Table Chart
Structural Shapes & Materials Menu
Engineering Materials Menu
Rectangle Structural Tube Per. ASTM 1085, table chart HSS Hollow Structural Section Square Structural Tube. This specification covers cold-formed welded carbon steel hollow structural sections (HSS) for welded or bolted construction.
h = Height
w = Width
t = Wall thickness
I = Area moment of inertia
S = Elastic section modulus
Z = Plastic section modulus
J = Torsional stiffness of cross section
C = Tortional shear constant or cross section
A = Section area
r = Radius of Gyration
Notes:
- Cold formed and welded
- Yield Stress Round 50 ksi min - 70 ksi max
- Tensile stress 65 ksi min
- Wall thickness -5%
- Mass tolerance -3.5%
- CVN 25 ft-lbs at 40 degrees F
- Heat treating optional
Rectangle Square Hollow structural sections (HSS) per ASTM 1085 Table Chart
Shape |
Design Wall
Thickness, t in. |
Nominal
Wt lb/ft |
Area, A
in2 |
b/t
h/t
Axis x - x
Axis Y-Y
Torsion |
Surface Area |
I |
S |
r |
Z |
I |
S |
r |
Z |
J |
C |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
ft2/ft |
24 x 12 x 3/4 |
0.750 |
171.16 |
50.3 |
12.4 |
28.4 |
3650 |
304 |
8.52 |
382 |
1240 |
207 |
4.97 |
235 |
3030 |
391 |
5.79 |
x 5/8 |
0.625 |
144.39 |
42.4 |
15.6 |
34.8 |
3130 |
261 |
8.59 |
325 |
1070 |
178 |
5.02 |
201 |
2590 |
331 |
5.82 |
x 1/2 |
0.500 |
116.91 |
34.4 |
20.4 |
44.4 |
2580 |
215 |
8.66 |
266 |
883 |
147 |
5.07 |
164 |
2120 |
270 |
5.86 |
20 x 12 x 3/4 |
0.750 |
150.75 |
44.3 |
12.4 |
23.1 |
2320 |
232 |
7.24 |
287 |
1050 |
175 |
4.87 |
202 |
2360 |
323 |
5.12 |
x 5/8 |
0.625 |
127.37 |
37.4 |
15.6 |
28.4 |
2000 |
200 |
7.31 |
245 |
904 |
151 |
4.92 |
172 |
2010 |
275 |
5.15 |
x 1/2 |
0.500 |
103.30 |
30.4 |
20.4 |
36.4 |
1650 |
165 |
7.37 |
201 |
750 |
125 |
4.97 |
141 |
1650 |
224 |
5.19 |
x 3/8 |
0.375 |
78.52 |
23.1 |
28.8 |
50.1 |
1280 |
128 |
7.44 |
154 |
583 |
97.2 |
5.02 |
109 |
1270 |
171 |
5.23 |
x 5/16 |
0.313 |
65.87 |
19.4 |
35.1 |
60.7 |
1080 |
108 |
7.46 |
130 |
495 |
82.5 |
5.05 |
91.9 |
1070 |
144 |
5.24 |
20 x 8 x 5/8 |
0.625 |
110.36 |
32.4 |
9.20 |
28.4 |
1530 |
153 |
6.87 |
197 |
358 |
89.5 |
3.32 |
103 |
973 |
178 |
4.49 |
x 1/2 |
0.500 |
89.68 |
26.4 |
12.4 |
36.4 |
1270 |
127 |
6.94 |
162 |
300 |
75.0 |
3.37 |
84.7 |
806 |
146 |
4.52 |
x 3/8 |
0.375 |
68.31 |
20.1 |
18.1 |
50.1 |
988 |
98.8 |
7.01 |
125 |
236 |
59.0 |
3.43 |
65.6 |
625 |
112 |
4.56 |
x 5/16 |
0.313 |
57.36 |
16.9 |
22.4 |
60.7 |
840 |
84.0 |
7.05 |
106 |
202 |
50.5 |
3.46 |
55.6 |
530 |
94.6 |
4.58 |
20 x 4 x 1/2 |
0.500 |
76.07 |
22.4 |
4.40 |
36.4 |
889 |
88.9 |
6.30 |
123 |
61.6 |
30.8 |
1.66 |
36.0 |
205 |
67.8 |
3.86 |
x 3/8 |
0.375 |
58.10 |
17.1 |
7.47 |
50.1 |
699 |
69.9 |
6.39 |
95.3 |
50.3 |
25.2 |
1.72 |
28.5 |
165 |
53.2 |
3.89 |
x 5/16 |
0.313 |
48.86 |
14.4 |
9.58 |
60.7 |
597 |
59.7 |
6.44 |
80.9 |
43.7 |
21.8 |
1.74 |
24.4 |
143 |
45.3 |
3.91 |
x 1/4 |
0.250 |
39.43 |
11.6 |
12.8 |
76.8 |
488 |
48.8 |
6.49 |
65.7 |
36.4 |
18.2 |
1.77 |
20.0 |
118 |
37.0 |
3.93 |
18 x 6 x 5/8 |
0.625 |
93.34 |
27.4 |
6.00 |
25.2 |
977 |
109 |
5.97 |
144 |
166 |
55.3 |
2.46 |
64.6 |
489 |
116 |
3.82 |
x 1/2 |
0.500 |
76.07 |
22.4 |
8.40 |
32.4 |
818 |
90.9 |
6.04 |
119 |
142 |
47.3 |
2.52 |
53.9 |
410 |
95.8 |
3.86 |
x 3/8 |
0.375 |
58.10 |
17.1 |
12.8 |
44.8 |
641 |
71.2 |
6.12 |
92.2 |
113 |
37.7 |
2.57 |
42.1 |
322 |
74.2 |
3.89 |
x 5/16 |
0.313 |
48.86 |
14.4 |
16.0 |
54.3 |
547 |
60.8 |
6.16 |
78.2 |
97.1 |
32.4 |
2.60 |
35.8 |
275 |
62.8 |
3.91 |
x 1/4 |
0.250 |
39.43 |
11.6 |
20.8 |
68.8 |
447 |
49.7 |
6.21 |
63.5 |
80.0 |
26.7 |
2.63 |
29.2 |
224 |
51.0 |
3.93 |
16 x 12 x 3/4 |
0.750 |
130.33 |
38.3 |
12.4 |
17.7 |
1340 |
168 |
5.91 |
205 |
856 |
143 |
4.73 |
168 |
1710 |
256 |
4.45 |
x 5/8 |
0.625 |
110.36 |
32.4 |
15.6 |
22.0 |
1160 |
145 |
5.98 |
175 |
742 |
124 |
4.79 |
144 |
1460 |
218 |
4.49 |
x 1/2 |
0.500 |
89.68 |
26.4 |
20.4 |
28.4 |
962 |
120 |
6.04 |
144 |
618 |
103 |
4.84 |
118 |
1200 |
178 |
4.52 |
x 3/8 |
0.375 |
68.31 |
20.1 |
28.8 |
39.5 |
748 |
93.5 |
6.10 |
111 |
482 |
80.3 |
4.90 |
91.3 |
922 |
136 |
4.56 |
x 5/16 |
0.313 |
57.36 |
16.9 |
35.1 |
47.9 |
636 |
79.5 |
6.13 |
93.9 |
410 |
68.3 |
4.93 |
77.3 |
779 |
115 |
4.58 |
Shape
h x b x t |
Design Wall
Thickness, t in.
Nominal
Wt lb/ft
Area, A
in2
b/t
h/t
Axis x - x
Axis Y-Y
Torsion |
Surface Area |
I |
S |
r |
Z |
I |
S |
r |
Z |
J |
C |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
ft2/ft |
16 x 8 x 5/8 |
0.625 |
93.34 |
27.4 |
9.20 |
22.0 |
863 |
108 |
5.61 |
137 |
290 |
72.5 |
3.25 |
84.1 |
723 |
141 |
3.82 |
x 1/2 |
0.500 |
76.07 |
22.4 |
12.4 |
28.4 |
722 |
90.2 |
5.68 |
113 |
244 |
61.0 |
3.30 |
69.7 |
599 |
116 |
3.86 |
x 3/8 |
0.375 |
58.10 |
17.1 |
18.1 |
39.5 |
565 |
70.6 |
5.75 |
87.6 |
193 |
48.2 |
3.36 |
54.2 |
465 |
89.2 |
3.89 |
x 5/16 |
0.313 |
48.86 |
14.4 |
22.4 |
47.9 |
482 |
60.2 |
5.79 |
74.3 |
165 |
41.2 |
3.39 |
46.0 |
395 |
75.4 |
3.91 |
x 1/4 |
0.250 |
39.43 |
11.6 |
28.8 |
60.8 |
393 |
49.1 |
5.82 |
60.3 |
135 |
33.8 |
3.41 |
37.4 |
321 |
61.0 |
3.93 |
16 x 4 x 5/8 |
0.625 |
76.33 |
22.4 |
2.80 |
22.0 |
568 |
71.0 |
5.04 |
98.5 |
56.4 |
28.2 |
1.59 |
34.2 |
182 |
63.9 |
3.15 |
x 1/2 |
0.500 |
62.46 |
18.4 |
4.40 |
28.4 |
481 |
60.1 |
5.11 |
82.2 |
49.3 |
24.6 |
1.64 |
29.0 |
157 |
53.8 |
3.19 |
x 3/8 |
0.375 |
47.90 |
14.1 |
7.47 |
39.5 |
382 |
47.8 |
5.21 |
64.2 |
40.4 |
20.2 |
1.69 |
23.0 |
127 |
42.3 |
3.23 |
x 5/16 |
0.313 |
40.35 |
11.9 |
9.58 |
47.9 |
328 |
41.0 |
5.25 |
54.6 |
35.2 |
17.6 |
1.72 |
19.8 |
110 |
36.1 |
3.24 |
x 1/4 |
0.250 |
32.63 |
9.59 |
12.8 |
60.8 |
269 |
33.6 |
5.30 |
44.5 |
29.3 |
14.6 |
1.75 |
16.2 |
90.6 |
29.5 |
3.26 |
x 3/16 |
0.188 |
24.73 |
7.29 |
18.1 |
81.9 |
208 |
26.0 |
5.34 |
34.1 |
23.0 |
11.5 |
1.78 |
12.5 |
70.3 |
22.6 |
3.28 |
14 x 10 x 5/8 |
0.625 |
93.34 |
27.4 |
12.4 |
18.8 |
728 |
104 |
5.15 |
127 |
431 |
86.2 |
3.97 |
101 |
885 |
156 |
3.82 |
x 1/2 |
0.500 |
76.07 |
22.4 |
16.4 |
24.4 |
608 |
86.9 |
5.21 |
105 |
361 |
72.2 |
4.01 |
83.6 |
730 |
128 |
3.86 |
x 3/8 |
0.375 |
58.10 |
17.1 |
23.5 |
34.1 |
476 |
68.0 |
5.28 |
81.5 |
284 |
56.8 |
4.08 |
64.8 |
564 |
98.2 |
3.89 |
x 5/16 |
0.313 |
48.86 |
14.4 |
28.7 |
41.5 |
406 |
58.0 |
5.31 |
69.1 |
242 |
48.4 |
4.10 |
55.0 |
478 |
82.9 |
3.91 |
x 1/4 |
0.250 |
39.43 |
11.6 |
36.8 |
52.8 |
331 |
47.3 |
5.34 |
56.0 |
198 |
39.6 |
4.13 |
44.6 |
387 |
67.0 |
3.93 |
14 x 6 x 5/8 |
0.625 |
76.33 |
22.4 |
6.00 |
18.8 |
504 |
72.0 |
4.74 |
94.0 |
130 |
43.3 |
2.41 |
51.2 |
352 |
88.9 |
3.15 |
x 1/2 |
0.500 |
62.46 |
18.4 |
8.40 |
24.4 |
426 |
60.9 |
4.81 |
78.3 |
111 |
37.0 |
2.46 |
42.9 |
296 |
73.8 |
3.19 |
x 3/8 |
0.375 |
47.90 |
14.1 |
12.8 |
34.1 |
337 |
48.1 |
4.89 |
61.1 |
89.1 |
29.7 |
2.51 |
33.6 |
233 |
57.3 |
3.23 |
x 5/16 |
0.313 |
40.35 |
11.9 |
16.0 |
41.5 |
289 |
41.3 |
4.93 |
51.9 |
76.9 |
25.6 |
2.54 |
28.7 |
199 |
48.6 |
3.24 |
x 1/4 |
0.250 |
32.63 |
9.59 |
20.8 |
52.8 |
237 |
33.9 |
4.97 |
42.3 |
63.4 |
21.1 |
2.57 |
23.4 |
162 |
39.5 |
3.26 |
x 3/16 |
0.188 |
24.73 |
7.29 |
28.7 |
71.3 |
182 |
26.0 |
5.00 |
32.4 |
49.2 |
16.4 |
2.60 |
18.0 |
125 |
30.2 |
3.28 |
14 x 4 x 5/8 |
0.625 |
67.82 |
19.9 |
2.80 |
18.8 |
392 |
56.0 |
4.44 |
77.3 |
49.2 |
24.6 |
1.57 |
30.0 |
154 |
55.5 |
2.82 |
x 1/2 |
0.500 |
55.66 |
16.4 |
4.40 |
24.4 |
335 |
47.9 |
4.52 |
64.8 |
43.1 |
21.6 |
1.62 |
25.5 |
134 |
46.8 |
2.86 |
x 3/8 |
0.375 |
42.79 |
12.6 |
7.47 |
34.1 |
267 |
38.1 |
4.60 |
50.8 |
35.4 |
17.7 |
1.68 |
20.3 |
108 |
36.8 |
2.89 |
x 5/16 |
0.313 |
36.10 |
10.6 |
9.58 |
41.5 |
230 |
32.9 |
4.66 |
43.4 |
30.9 |
15.4 |
1.71 |
17.4 |
93.2 |
31.5 |
2.91 |
x 1/4 |
0.250 |
29.23 |
8.59 |
12.8 |
52.8 |
189 |
27.0 |
4.69 |
35.4 |
25.8 |
12.9 |
1.73 |
14.3 |
77.0 |
25.7 |
2.93 |
x 3/16 |
0.188 |
22.18 |
6.54 |
18.1 |
71.3 |
147 |
21.0 |
4.74 |
27.2 |
20.3 |
10.2 |
1.76 |
11.1 |
59.8 |
19.8 |
2.95 |
Shape
h x b x t |
Design Wall
Thickness, t in.
Nominal
Wt lb/ft
Area, A
in2
b/t
h/t
Axis x - x
Axis Y-Y
Torsion |
Surface Area |
I |
S |
r |
Z |
I |
S |
r |
Z |
J |
C |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
ft2/ft |
12 x 10 x 1/2 |
0.500 |
69.27 |
20.4 |
16.4 |
20.4 |
419 |
69.8 |
4.53 |
83.9 |
316 |
63.2 |
3.94 |
74.1 |
581 |
109 |
3.52 |
x 3/8 |
0.375 |
53.00 |
15.6 |
23.5 |
28.8 |
330 |
55.0 |
4.60 |
65.2 |
249 |
49.8 |
4.00 |
57.6 |
450 |
83.7 |
3.56 |
x 5/16 |
0.313 |
44.60 |
13.1 |
28.7 |
35.1 |
282 |
47.0 |
4.64 |
55.3 |
213 |
42.6 |
4.03 |
48.9 |
381 |
70.8 |
3.58 |
x 1/4 |
0.250 |
36.03 |
10.6 |
36.8 |
44.8 |
230 |
38.3 |
4.66 |
44.9 |
174 |
34.8 |
4.05 |
39.7 |
309 |
57.2 |
3.60 |
12 x 8 x 5/8 |
0.625 |
76.33 |
22.4 |
9.20 |
15.6 |
419 |
69.8 |
4.32 |
87.1 |
221 |
55.2 |
3.14 |
65.6 |
481 |
104 |
3.15 |
x 1/2 |
0.500 |
62.46 |
18.4 |
12.4 |
20.4 |
353 |
58.8 |
4.38 |
72.4 |
188 |
47.0 |
3.20 |
54.7 |
401 |
85.8 |
3.19 |
x 3/8 |
0.375 |
47.90 |
14.1 |
18.1 |
28.8 |
279 |
46.5 |
4.45 |
56.5 |
149 |
37.2 |
3.25 |
42.7 |
312 |
66.3 |
3.23 |
x 5/16 |
0.313 |
40.35 |
11.9 |
22.4 |
35.1 |
239 |
39.8 |
4.48 |
48.0 |
128 |
32.0 |
3.28 |
36.4 |
265 |
56.1 |
3.24 |
x 1/4 |
0.250 |
32.63 |
9.59 |
28.8 |
44.8 |
196 |
32.7 |
4.52 |
39.1 |
105 |
26.2 |
3.31 |
29.6 |
216 |
45.5 |
3.26 |
x 3/16 |
0.188 |
24.73 |
7.29 |
39.4 |
60.6 |
151 |
25.2 |
4.55 |
29.9 |
81.3 |
20.3 |
3.34 |
22.7 |
165 |
34.7 |
3.28 |
12 x 6 x 5/8 |
0.625 |
67.82 |
19.9 |
6.00 |
15.6 |
338 |
56.3 |
4.12 |
72.9 |
112 |
37.3 |
2.37 |
44.5 |
286 |
75.5 |
2.82 |
x 1/2 |
0.500 |
55.66 |
16.4 |
8.40 |
20.4 |
287 |
47.8 |
4.18 |
60.9 |
96.0 |
32.0 |
2.42 |
37.4 |
241 |
62.8 |
2.86 |
x 3/8 |
0.375 |
42.79 |
12.6 |
12.8 |
28.8 |
228 |
38.0 |
4.25 |
47.7 |
77.3 |
25.8 |
2.48 |
29.4 |
190 |
48.8 |
2.89 |
x 5/16 |
0.313 |
36.10 |
10.6 |
16.0 |
35.1 |
196 |
32.7 |
4.30 |
40.7 |
66.7 |
22.2 |
2.51 |
25.1 |
162 |
41.5 |
2.91 |
x 1/4 |
0.250 |
29.23 |
8.59 |
20.8 |
44.8 |
161 |
26.8 |
4.33 |
33.2 |
55.2 |
18.4 |
2.53 |
20.6 |
132 |
33.7 |
2.93 |
x 3/16 |
0.188 |
22.18 |
6.54 |
28.7 |
60.6 |
125 |
20.8 |
4.37 |
25.5 |
42.9 |
14.3 |
2.56 |
15.8 |
102 |
25.8 |
2.95 |
12 x 4 x 5/8 |
0.625 |
59.32 |
17.4 |
2.80 |
15.6 |
257 |
42.8 |
3.84 |
58.6 |
42.0 |
21.0 |
1.55 |
25.8 |
127 |
47.0 |
2.49 |
x 1/2 |
0.500 |
48.85 |
14.4 |
4.40 |
20.4 |
221 |
36.8 |
3.92 |
49.4 |
37.0 |
18.5 |
1.60 |
22.0 |
110 |
39.8 |
2.52 |
x 3/8 |
0.375 |
37.69 |
11.1 |
7.47 |
28.8 |
178 |
29.7 |
4.00 |
39.0 |
30.5 |
15.2 |
1.66 |
17.6 |
89.0 |
31.4 |
2.56 |
x 5/16 |
0.313 |
31.84 |
9.37 |
9.58 |
35.1 |
153 |
25.5 |
4.04 |
33.4 |
26.7 |
13.4 |
1.69 |
15.1 |
77.0 |
26.9 |
2.58 |
x 1/4 |
0.250 |
25.82 |
7.59 |
12.8 |
44.8 |
127 |
21.2 |
4.09 |
27.3 |
22.3 |
11.2 |
1.71 |
12.5 |
63.6 |
22.0 |
2.60 |
x 3/16 |
0.188 |
19.63 |
5.8 |
18.1 |
60.6 |
98.4 |
16.4 |
4.12 |
21.0 |
17.5 |
8.75 |
1.74 |
9.66 |
49.4 |
16.9 |
2.61 |
12 x 3-1/2 x 3/8 |
0.375 |
36.41 |
10.7 |
6.13 |
28.8 |
165 |
27.5 |
3.93 |
36.8 |
22.4 |
12.8 |
1.45 |
14.9 |
68.3 |
27.0 |
2.48 |
x 5/16 |
0.313 |
30.78 |
9.06 |
7.98 |
35.1 |
143 |
23.8 |
3.97 |
31.6 |
19.7 |
11.3 |
1.47 |
12.8 |
59.4 |
23.2 |
2.49 |
12 x 3 x 5/16 |
0.313 |
29.72 |
8.75 |
6.38 |
35.1 |
132 |
22.0 |
3.88 |
29.7 |
13.8 |
9.20 |
1.26 |
10.6 |
43.7 |
19.5 |
2.41 |
x 1/4 |
0.250 |
24.12 |
7.09 |
8.80 |
44.8 |
109 |
18.2 |
3.92 |
24.4 |
11.7 |
7.80 |
1.28 |
8.80 |
36.5 |
16.1 |
2.43 |
x 3/16 |
0.188 |
18.35 |
5.41 |
12.8 |
60.6 |
85 |
14.2 |
3.96 |
18.8 |
9.30 |
6.20 |
1.31 |
6.86 |
28.7 |
12.5 |
2.45 |
Shape
h x b x t |
Design Wall
Thickness, t in.
Nominal
Wt lb/ft
Area, A
in2
b/t
h/t
Axis x - x
Axis Y-Y
Torsion |
Surface Area |
I |
S |
r |
Z |
I |
S |
r |
Z |
J |
C |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
ft2/ft |
12 x 2 x 5/16 |
0.313 |
27.59 |
8.12 |
3.19 |
35.1 |
111 |
18.5 |
3.70 |
26.1 |
5.33 |
5.33 |
0.810 |
6.39 |
18.4 |
12.2 |
2.24 |
x 1/4 |
0.250 |
22.42 |
6.59 |
4.80 |
44.8 |
92.2 |
15.4 |
3.74 |
21.4 |
4.62 |
4.62 |
0.837 |
5.38 |
15.9 |
10.2 |
2.26 |
x 3/16 |
0.188 |
17.08 |
5.03 |
7.44 |
60.6 |
72.2 |
12.0 |
3.79 |
16.6 |
3.77 |
3.77 |
0.866 |
4.25 |
12.8 |
8.02 |
2.28 |
10 x 8 x 5/8 |
0.625 |
67.82 |
19.9 |
9.20 |
12.4 |
266 |
53.2 |
3.66 |
65.9 |
187 |
46.8 |
3.07 |
56.4 |
367 |
85.5 |
2.82 |
x 1/2 |
0.500 |
55.66 |
16.4 |
12.4 |
16.4 |
226 |
45.2 |
3.71 |
55.1 |
160 |
40.0 |
3.12 |
47.2 |
306 |
70.8 |
2.86 |
x 3/8 |
0.375 |
42.79 |
12.6 |
18.1 |
23.5 |
180 |
36.0 |
3.78 |
43.1 |
127 |
31.8 |
3.17 |
37.0 |
239 |
54.8 |
2.89 |
x 5/16 |
0.313 |
36.10 |
10.6 |
22.4 |
28.7 |
154 |
30.8 |
3.81 |
36.8 |
110 |
27.5 |
3.22 |
31.6 |
203 |
46.5 |
2.91 |
x 1/4 |
0.250 |
29.23 |
8.59 |
28.8 |
36.8 |
127 |
25.4 |
3.85 |
30.0 |
90.2 |
22.6 |
3.24 |
25.8 |
166 |
37.7 |
2.93 |
x 3/16 |
0.188 |
22.18 |
6.54 |
39.4 |
50.0 |
98.1 |
19.6 |
3.87 |
23.0 |
69.8 |
17.4 |
3.27 |
19.8 |
127 |
28.8 |
2.95 |
10 x 6 x 5/8 |
0.625 |
59.32 |
17.4 |
6.00 |
12.4 |
211 |
42.2 |
3.48 |
54.2 |
93.6 |
31.2 |
2.32 |
37.7 |
221 |
62.0 |
2.49 |
x 1/2 |
0.500 |
48.85 |
14.4 |
8.40 |
16.4 |
181 |
36.2 |
3.55 |
45.6 |
80.9 |
27.0 |
2.37 |
31.9 |
187 |
51.8 |
2.52 |
x 3/8 |
0.375 |
37.69 |
11.1 |
12.8 |
23.5 |
145 |
29.0 |
3.61 |
35.9 |
65.4 |
21.8 |
2.43 |
25.2 |
147 |
40.4 |
2.56 |
x 5/16 |
0.313 |
31.84 |
9.37 |
16.0 |
28.7 |
125 |
25.0 |
3.65 |
30.7 |
56.6 |
18.9 |
2.46 |
21.6 |
126 |
34.4 |
2.58 |
x 1/4 |
0.250 |
25.82 |
7.59 |
20.8 |
36.8 |
103 |
20.6 |
3.68 |
25.1 |
46.9 |
15.6 |
2.49 |
17.7 |
103 |
28.0 |
2.60 |
x 3/16 |
0.188 |
19.63 |
5.78 |
28.7 |
50.0 |
80.0 |
16.0 |
3.72 |
19.3 |
36.5 |
12.2 |
2.51 |
13.6 |
79.3 |
21.4 |
2.61 |
10 x 5 x 3/8 |
0.375 |
35.13 |
10.3 |
10.1 |
23.5 |
128 |
25.6 |
3.53 |
32.3 |
42.9 |
17.2 |
2.04 |
19.9 |
107 |
33.2 |
2.39 |
x 5/16 |
0.313 |
29.72 |
8.75 |
12.8 |
28.7 |
110 |
22.0 |
3.55 |
27.7 |
37.3 |
14.9 |
2.06 |
17.0 |
91.6 |
28.3 |
2.41 |
x 1/4 |
0.250 |
24.12 |
7.09 |
16.8 |
36.8 |
91.2 |
18.2 |
3.59 |
22.7 |
31.1 |
12.4 |
2.09 |
14.0 |
75.2 |
23.1 |
2.43 |
x 3/16 |
0.188 |
18.35 |
5.41 |
23.4 |
50.0 |
70.9 |
14.2 |
3.62 |
17.5 |
24.3 |
9.72 |
2.12 |
10.8 |
58.1 |
17.7 |
2.45 |
10 x 4 x 5/8 |
0.625 |
50.81 |
14.9 |
2.80 |
12.4 |
156 |
31.2 |
3.24 |
42.5 |
34.8 |
17.4 |
1.53 |
21.6 |
100 |
38.6 |
2.15 |
x 1/2 |
0.500 |
42.05 |
12.4 |
4.40 |
16.4 |
136 |
27.2 |
3.31 |
36.1 |
30.8 |
15.4 |
1.58 |
18.5 |
86.9 |
32.8 |
2.19 |
x 3/8 |
0.375 |
32.58 |
9.58 |
7.47 |
23.5 |
110 |
22.0 |
3.39 |
28.7 |
25.5 |
12.8 |
1.63 |
14.9 |
70.4 |
26.0 |
2.23 |
x 5/16 |
0.313 |
27.59 |
8.12 |
9.58 |
28.7 |
95.6 |
19.1 |
3.43 |
24.6 |
22.4 |
11.2 |
1.66 |
12.8 |
60.9 |
22.2 |
2.24 |
x 1/4 |
0.250 |
22.42 |
6.59 |
12.8 |
36.8 |
79.3 |
15.9 |
3.47 |
20.2 |
18.8 |
9.40 |
1.69 |
10.6 |
50.4 |
18.2 |
2.26 |
x 3/16 |
0.188 |
17.08 |
5.03 |
18.1 |
50.0 |
61.9 |
12.4 |
3.51 |
15.6 |
14.8 |
7.40 |
1.72 |
8.22 |
39.2 |
14.0 |
2.28 |
Shape
h x b x t |
Design Wall
Thickness, t in.
Nominal
Wt lb/ft
Area, A
in2
b/t
h/t
Axis x - x
Axis Y-Y
Torsion |
Surface Area |
I |
S |
r |
Z |
I |
S |
r |
Z |
J |
C |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
ft2/ft |
10 x 3-1/2 x 1/2 |
0.500 |
40.34 |
11.9 |
3.40 |
16.4 |
124 |
24.8 |
3.23 |
33.7 |
22.3 |
12.7 |
1.37 |
15.5 |
66.2 |
28.0 |
2.11 |
x 3/8 |
0.375 |
31.31 |
9.20 |
6.13 |
23.5 |
102 |
20.4 |
3.33 |
26.9 |
18.7 |
10.7 |
1.43 |
12.5 |
54.3 |
22.4 |
2.14 |
x 5/16 |
0.313 |
26.53 |
7.81 |
7.98 |
28.7 |
88.2 |
17.6 |
3.36 |
23.1 |
16.5 |
9.43 |
1.45 |
10.8 |
47.3 |
19.2 |
2.16 |
x 1/4 |
0.250 |
21.57 |
6.34 |
10.8 |
36.8 |
73.4 |
14.7 |
3.40 |
19.0 |
13.9 |
7.94 |
1.48 |
8.98 |
39.3 |
15.8 |
2.18 |
x 3/16 |
0.188 |
16.44 |
4.84 |
15.4 |
50.0 |
57.4 |
11.5 |
3.44 |
14.7 |
11.0 |
6.29 |
1.51 |
6.99 |
30.7 |
12.2 |
2.20 |
10 x 3 x 3/8 |
0.375 |
30.03 |
8.83 |
4.80 |
23.5 |
92.8 |
18.6 |
3.24 |
25.1 |
13.0 |
8.67 |
1.21 |
10.3 |
39.8 |
18.7 |
2.06 |
x 5/16 |
0.313 |
25.46 |
7.49 |
6.38 |
28.7 |
80.9 |
16.2 |
3.29 |
21.6 |
11.5 |
7.67 |
1.24 |
8.93 |
34.9 |
16.2 |
2.08 |
x 1/4 |
0.250 |
20.72 |
6.09 |
8.80 |
36.8 |
67.4 |
13.5 |
3.33 |
17.8 |
9.79 |
6.53 |
1.27 |
7.42 |
29.3 |
13.3 |
2.10 |
x 3/16 |
0.188 |
15.80 |
4.66 |
12.8 |
50.0 |
52.8 |
10.6 |
3.37 |
13.8 |
7.82 |
5.21 |
1.30 |
5.80 |
23.0 |
10.3 |
2.11 |
10 x 2 x 3/8 |
0.375 |
27.48 |
8.08 |
2.13 |
23.5 |
75.4 |
15.1 |
3.05 |
21.5 |
4.87 |
4.87 |
0.776 |
6.05 |
16.5 |
11.5 |
1.89 |
x 5/16 |
0.313 |
23.34 |
6.87 |
3.19 |
28.7 |
66.2 |
13.2 |
3.10 |
18.6 |
4.43 |
4.43 |
0.803 |
5.34 |
14.9 |
10.1 |
1.91 |
x 1/4 |
0.250 |
19.02 |
5.59 |
4.80 |
36.8 |
55.6 |
11.1 |
3.15 |
15.4 |
3.85 |
3.85 |
0.830 |
4.50 |
12.8 |
8.47 |
1.93 |
x 3/16 |
0.188 |
14.53 |
4.28 |
7.44 |
50.0 |
43.8 |
8.8 |
3.20 |
11.9 |
3.15 |
3.15 |
0.858 |
3.57 |
10.4 |
6.66 |
1.95 |
9 x 7 x 5/8 |
0.625 |
59.32 |
17.4 |
7.60 |
10.8 |
183 |
40.7 |
3.24 |
51.0 |
123 |
35.1 |
2.66 |
42.8 |
248 |
65.8 |
2.49 |
x 1/2 |
0.500 |
48.85 |
14.4 |
10.4 |
14.4 |
157 |
34.9 |
3.30 |
42.9 |
106 |
30.3 |
2.71 |
36.1 |
209 |
54.8 |
2.52 |
x 3/8 |
0.375 |
37.69 |
11.1 |
15.5 |
20.8 |
126 |
28.0 |
3.37 |
33.8 |
85.2 |
24.3 |
2.77 |
28.4 |
164 |
42.7 |
2.56 |
x 5/16 |
0.313 |
31.84 |
9.37 |
19.2 |
25.6 |
108 |
24.0 |
3.40 |
28.9 |
73.6 |
21.0 |
2.80 |
24.3 |
140 |
36.2 |
2.58 |
x 1/4 |
0.250 |
25.82 |
7.59 |
24.8 |
32.8 |
89.4 |
19.9 |
3.43 |
23.6 |
60.8 |
17.4 |
2.83 |
19.9 |
114 |
29.5 |
2.60 |
x 3/16 |
0.188 |
19.63 |
5.78 |
34.0 |
44.7 |
69.4 |
15.4 |
3.47 |
18.2 |
47.3 |
13.5 |
2.86 |
15.3 |
87.9 |
22.5 |
2.61 |
9 x 5 x 5/8 |
0.625 |
50.81 |
14.9 |
4.40 |
10.8 |
139 |
30.9 |
3.05 |
40.5 |
54.1 |
21.6 |
1.91 |
26.6 |
135 |
44.9 |
2.15 |
x 1/2 |
0.500 |
42.05 |
12.4 |
6.40 |
14.4 |
121 |
26.9 |
3.12 |
34.4 |
47.4 |
19.0 |
1.96 |
22.7 |
115 |
37.8 |
2.19 |
x 3/8 |
0.375 |
32.58 |
9.58 |
10.1 |
20.8 |
97.8 |
21.7 |
3.20 |
27.3 |
38.9 |
15.6 |
2.02 |
18.1 |
92.2 |
29.7 |
2.23 |
x 5/16 |
0.313 |
27.59 |
8.12 |
12.8 |
25.6 |
84.7 |
18.8 |
3.23 |
23.4 |
33.9 |
13.6 |
2.04 |
15.6 |
79.3 |
25.4 |
2.24 |
x 1/4 |
0.250 |
22.42 |
6.59 |
16.8 |
32.8 |
70.3 |
15.6 |
3.27 |
19.3 |
28.2 |
11.3 |
2.07 |
12.8 |
65.2 |
20.7 |
2.26 |
x 3/16 |
0.188 |
17.08 |
5.03 |
23.4 |
44.7 |
54.8 |
12.2 |
3.30 |
14.9 |
22.1 |
8.84 |
2.10 |
9.93 |
50.4 |
15.9 |
2.28 |
9 x 3 x 1/2 |
0.500 |
35.24 |
10.4 |
2.40 |
14.4 |
84.5 |
18.8 |
2.85 |
25.9 |
13.7 |
9.13 |
1.15 |
11.3 |
41.6 |
20.8 |
1.86 |
x 3/8 |
0.375 |
27.48 |
8.08 |
4.80 |
20.8 |
69.9 |
15.5 |
2.94 |
20.9 |
11.7 |
7.80 |
1.20 |
9.29 |
34.9 |
16.8 |
1.89 |
x 5/16 |
0.313 |
23.34 |
6.87 |
6.38 |
25.6 |
61.1 |
13.6 |
2.98 |
18.0 |
10.4 |
6.93 |
1.23 |
8.09 |
30.6 |
14.5 |
1.91 |
x 1/4 |
0.250 |
19.02 |
5.59 |
8.80 |
32.8 |
51.1 |
11.4 |
3.02 |
14.9 |
8.85 |
5.90 |
1.26 |
6.73 |
25.6 |
12.0 |
1.93 |
x 3/16 |
0.188 |
14.53 |
4.28 |
12.8 |
44.7 |
40.2 |
8.93 |
3.06 |
11.6 |
7.07 |
4.71 |
1.29 |
5.27 |
20.2 |
9.29 |
1.95 |
Shape
h x b x t |
Design Wall
Thickness, t in.
Nominal
Wt lb/ft
Area, A
in2
b/t
h/t
Axis x - x
Axis Y-Y
Torsion |
Surface Area |
I |
S |
r |
Z |
I |
S |
r |
Z |
J |
C |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
ft2/ft |
8 x 6 x 5/8 |
0.625 |
50.81 |
14.9 |
6.00 |
9.20 |
119 |
29.8 |
2.83 |
38.0 |
75.5 |
25.2 |
2.25 |
31.0 |
158 |
48.6 |
2.15 |
x 1/2 |
0.500 |
42.05 |
12.4 |
8.40 |
12.4 |
103 |
25.8 |
2.88 |
32.2 |
65.7 |
21.9 |
2.30 |
26.4 |
135 |
40.8 |
2.19 |
x 3/8 |
0.375 |
32.58 |
9.58 |
12.8 |
18.1 |
83.7 |
20.9 |
2.96 |
25.6 |
53.5 |
17.8 |
2.36 |
21.0 |
107 |
32.0 |
2.23 |
x 5/16 |
0.313 |
27.59 |
8.12 |
16.0 |
22.4 |
72.5 |
18.1 |
2.99 |
22.0 |
46.5 |
15.5 |
2.39 |
18.0 |
91.4 |
27.2 |
2.24 |
x 1/4 |
0.250 |
22.42 |
6.59 |
20.8 |
28.8 |
60.1 |
15.0 |
3.02 |
18.0 |
38.6 |
12.9 |
2.42 |
14.8 |
74.9 |
22.2 |
2.26 |
x 3/16 |
0.188 |
17.08 |
5.03 |
28.7 |
39.4 |
46.9 |
11.7 |
3.05 |
13.9 |
30.2 |
10.1 |
2.45 |
11.4 |
57.7 |
17.0 |
2.28 |
8 x 4 x 5/8 |
0.625 |
42.30 |
12.4 |
2.80 |
9.20 |
85.2 |
21.3 |
2.62 |
28.8 |
27.6 |
13.8 |
1.49 |
17.3 |
73.2 |
30.2 |
1.82 |
x 1/2 |
0.500 |
35.24 |
10.4 |
4.40 |
12.4 |
75.2 |
18.8 |
2.69 |
24.7 |
24.6 |
12.3 |
1.54 |
15.0 |
64.1 |
25.8 |
1.86 |
x 3/8 |
0.375 |
27.48 |
8.08 |
7.47 |
18.1 |
61.9 |
15.5 |
2.77 |
19.9 |
20.6 |
10.3 |
1.60 |
12.2 |
52.2 |
20.5 |
1.89 |
x 5/16 |
0.313 |
23.34 |
6.87 |
9.58 |
22.4 |
54.0 |
13.5 |
2.80 |
17.1 |
18.1 |
9.05 |
1.62 |
10.5 |
45.2 |
17.6 |
1.91 |
x 1/4 |
0.250 |
19.02 |
5.59 |
12.8 |
28.8 |
45.1 |
11.3 |
2.84 |
14.1 |
15.3 |
7.65 |
1.65 |
8.72 |
37.5 |
14.5 |
1.93 |
x 3/16 |
0.188 |
14.53 |
4.28 |
18.1 |
39.4 |
35.4 |
8.85 |
2.88 |
11.0 |
12.1 |
6.05 |
1.68 |
6.79 |
29.2 |
11.2 |
1.95 |
8 x 3 x 1/2 |
0.500 |
31.84 |
9.36 |
2.40 |
12.4 |
61.1 |
15.3 |
2.55 |
21.0 |
12.1 |
8.07 |
1.14 |
10.1 |
35.7 |
18.3 |
1.69 |
x 3/8 |
0.375 |
24.93 |
7.33 |
4.80 |
18.1 |
51.0 |
12.8 |
2.64 |
17.0 |
10.4 |
6.93 |
1.19 |
8.31 |
29.9 |
14.8 |
1.73 |
x 5/16 |
0.313 |
21.21 |
6.24 |
6.38 |
22.4 |
44.8 |
11.2 |
2.68 |
14.7 |
9.26 |
6.17 |
1.22 |
7.25 |
26.3 |
12.8 |
1.74 |
x 1/4 |
0.250 |
17.32 |
5.09 |
8.80 |
28.8 |
37.6 |
9.40 |
2.72 |
12.2 |
7.90 |
5.27 |
1.25 |
6.05 |
22.1 |
10.6 |
1.76 |
x 3/16 |
0.188 |
13.25 |
3.90 |
12.8 |
39.4 |
29.7 |
7.42 |
2.76 |
9.51 |
6.33 |
4.22 |
1.27 |
4.74 |
17.4 |
8.23 |
1.78 |
8 x 2 x 3/8 |
0.375 |
22.37 |
6.58 |
2.13 |
18.1 |
40.1 |
10.0 |
2.47 |
14.2 |
3.86 |
3.86 |
0.766 |
4.83 |
12.6 |
9.09 |
1.56 |
x 5/16 |
0.313 |
19.08 |
5.62 |
3.19 |
22.4 |
35.5 |
8.88 |
2.51 |
12.3 |
3.53 |
3.53 |
0.793 |
4.28 |
11.4 |
8.00 |
1.58 |
x 1/4 |
0.250 |
15.62 |
4.59 |
4.80 |
28.8 |
30.1 |
7.52 |
2.56 |
10.3 |
3.08 |
3.08 |
0.819 |
3.63 |
9.84 |
6.72 |
1.60 |
x 3/16 |
0.188 |
11.97 |
3.53 |
7.44 |
39.4 |
23.9 |
5.98 |
2.60 |
8.04 |
2.53 |
2.53 |
0.847 |
2.89 |
7.95 |
5.30 |
1.61 |
7 x 5 x 1/2 |
0.500 |
35.24 |
10.4 |
6.40 |
10.4 |
63.5 |
18.1 |
2.47 |
23.1 |
37.3 |
14.9 |
1.89 |
18.2 |
79.9 |
28.8 |
1.86 |
x 3/8 |
0.375 |
27.48 |
8.08 |
10.1 |
15.5 |
52.2 |
14.9 |
2.54 |
18.5 |
30.8 |
12.3 |
1.95 |
14.6 |
64.2 |
22.8 |
1.89 |
x 5/16 |
0.313 |
23.34 |
6.87 |
12.8 |
19.2 |
45.5 |
13.0 |
2.57 |
16.0 |
27.0 |
10.8 |
1.98 |
12.6 |
55.4 |
19.5 |
1.91 |
x 1/4 |
0.250 |
19.02 |
5.59 |
16.8 |
24.8 |
38.0 |
10.9 |
2.61 |
13.2 |
22.6 |
9.04 |
2.01 |
10.4 |
45.6 |
16.0 |
1.93 |
x 3/16 |
0.188 |
14.53 |
4.28 |
23.4 |
34.0 |
29.8 |
8.51 |
2.64 |
10.2 |
17.8 |
7.12 |
2.04 |
8.12 |
35.3 |
12.3 |
1.95 |
Shape
h x b x t |
Design Wall
Thickness, t in.
Nominal
Wt lb/ft
Area, A
in2
b/t
h/t
Axis x - x
Axis Y-Y
Torsion |
Surface Area |
I |
S |
r |
Z |
I |
S |
r |
Z |
J |
C |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
ft2/ft |
7 x 4 x 1/2 |
0.500 |
31.84 |
9.36 |
4.40 |
10.4 |
52.9 |
15.1 |
2.38 |
19.8 |
21.6 |
10.8 |
1.52 |
13.3 |
53.0 |
22.3 |
1.69 |
x 3/8 |
0.375 |
24.93 |
7.33 |
7.47 |
15.5 |
44.0 |
12.6 |
2.45 |
16.0 |
18.1 |
9.05 |
1.57 |
10.8 |
43.3 |
17.8 |
1.73 |
x 5/16 |
0.313 |
21.21 |
6.24 |
9.58 |
19.2 |
38.5 |
11.0 |
2.48 |
13.9 |
16.0 |
8.00 |
1.60 |
9.37 |
37.6 |
15.3 |
1.74 |
x 1/4 |
0.250 |
17.32 |
5.09 |
12.8 |
24.8 |
32.3 |
9.23 |
2.52 |
11.5 |
13.5 |
6.75 |
1.63 |
7.78 |
31.2 |
12.6 |
1.76 |
x 3/16 |
0.188 |
13.25 |
3.90 |
18.1 |
34.0 |
25.5 |
7.29 |
2.56 |
8.93 |
10.7 |
5.35 |
1.66 |
6.07 |
24.3 |
9.74 |
1.78 |
7 x 3 x 1/2 |
0.500 |
28.43 |
8.36 |
2.40 |
10.4 |
42.3 |
12.1 |
2.25 |
16.6 |
10.5 |
7.00 |
1.12 |
8.84 |
29.8 |
15.8 |
1.52 |
x 3/8 |
0.375 |
22.37 |
6.58 |
4.80 |
15.5 |
35.7 |
10.2 |
2.33 |
13.5 |
9.10 |
6.07 |
1.18 |
7.32 |
25.1 |
12.8 |
1.56 |
x 5/16 |
0.313 |
19.08 |
5.62 |
6.38 |
19.2 |
31.5 |
9.00 |
2.37 |
11.8 |
8.13 |
5.42 |
1.20 |
6.41 |
22.1 |
11.1 |
1.58 |
x 1/4 |
0.250 |
15.62 |
4.59 |
8.80 |
24.8 |
26.6 |
7.60 |
2.41 |
9.8 |
6.95 |
4.63 |
1.23 |
5.36 |
18.5 |
9.22 |
1.60 |
x 3/16 |
0.188 |
11.97 |
3.53 |
12.8 |
34.0 |
21.1 |
6.03 |
2.44 |
7.65 |
5.58 |
3.72 |
1.26 |
4.21 |
14.6 |
7.18 |
1.61 |
7 x 2 x 1/4 |
0.250 |
13.91 |
4.09 |
4.80 |
24.8 |
20.9 |
5.97 |
2.26 |
8.10 |
2.70 |
2.70 |
0.812 |
3.19 |
8.36 |
5.85 |
1.43 |
3 x 16 |
0.188 |
10.70 |
3.15 |
7.44 |
34.0 |
16.7 |
4.77 |
2.30 |
6.37 |
2.22 |
2.22 |
0.840 |
2.54 |
6.76 |
4.62 |
1.45 |
6 x 5 x 1/2 |
0.500 |
31.84 |
9.36 |
6.40 |
8.40 |
43.0 |
14.3 |
2.14 |
18.1 |
32.2 |
12.9 |
1.85 |
16.0 |
62.9 |
24.3 |
1.69 |
x 3/8 |
0.375 |
24.93 |
7.33 |
10.1 |
12.8 |
35.7 |
11.9 |
2.21 |
14.7 |
26.8 |
10.7 |
1.91 |
12.9 |
50.9 |
19.3 |
1.73 |
x 5/16 |
0.313 |
21.21 |
6.24 |
12.8 |
16.0 |
31.3 |
10.4 |
2.24 |
12.7 |
23.5 |
9.40 |
1.94 |
11.2 |
44.0 |
16.6 |
1.74 |
x 1/4 |
0.250 |
17.32 |
5.09 |
16.8 |
20.8 |
26.2 |
8.73 |
2.27 |
10.5 |
19.8 |
7.92 |
1.97 |
9.26 |
36.3 |
13.6 |
1.76 |
x 3/16 |
0.188 |
13.25 |
3.90 |
23.4 |
28.7 |
20.7 |
6.90 |
2.30 |
8.17 |
15.6 |
6.24 |
2.00 |
7.21 |
28.2 |
10.5 |
1.78 |
6 x 4 x 1/2 |
0.500 |
28.43 |
8.36 |
4.40 |
8.40 |
35.4 |
11.8 |
2.06 |
15.4 |
18.5 |
9.25 |
1.49 |
11.5 |
42.1 |
18.8 |
1.52 |
x 3/8 |
0.375 |
22.37 |
6.58 |
7.47 |
12.8 |
29.7 |
9.9 |
2.12 |
12.5 |
15.7 |
7.85 |
1.54 |
9.44 |
34.6 |
15.1 |
1.56 |
x 5/16 |
0.313 |
19.08 |
5.62 |
9.58 |
16.0 |
26.2 |
8.73 |
2.16 |
10.9 |
13.9 |
6.95 |
1.57 |
8.22 |
30.1 |
13.0 |
1.58 |
x 1/4 |
0.250 |
15.62 |
4.59 |
12.8 |
20.8 |
22.1 |
7.37 |
2.19 |
9.06 |
11.7 |
5.85 |
1.60 |
6.84 |
25.0 |
10.7 |
1.60 |
x 3/16 |
0.188 |
11.97 |
3.53 |
18.1 |
28.7 |
17.5 |
5.83 |
2.23 |
7.07 |
9.34 |
4.67 |
1.63 |
5.36 |
19.6 |
8.30 |
1.61 |
6 x 3 x 1/2 |
0.500 |
25.03 |
7.36 |
2.40 |
8.40 |
27.8 |
9.27 |
1.94 |
12.6 |
8.96 |
5.97 |
1.10 |
7.59 |
23.9 |
13.3 |
1.36 |
x 3/8 |
0.375 |
19.82 |
5.83 |
4.80 |
12.8 |
23.8 |
7.93 |
2.02 |
10.4 |
7.80 |
5.20 |
1.16 |
6.34 |
20.3 |
10.9 |
1.39 |
x 5/16 |
0.313 |
16.96 |
4.99 |
6.38 |
16.0 |
21.1 |
7.03 |
2.06 |
9.12 |
6.99 |
4.66 |
1.18 |
5.56 |
17.9 |
9.45 |
1.41 |
x 1/4 |
0.250 |
13.91 |
4.09 |
8.80 |
20.8 |
17.9 |
5.97 |
2.09 |
7.62 |
6.00 |
4.00 |
1.21 |
4.67 |
15.1 |
7.85 |
1.43 |
x 3/16 |
0.188 |
10.70 |
3.15 |
12.8 |
28.7 |
14.3 |
4.77 |
2.13 |
5.98 |
4.84 |
3.23 |
1.24 |
3.69 |
11.9 |
6.12 |
1.45 |
Shape
h x b x t |
Design Wall
Thickness, t in.
Nominal
Wt lb/ft
Area, A
in2
b/t
h/t
Axis x - x
Axis Y-Y
Torsion |
Surface Area |
I |
S |
r |
Z |
I |
S |
r |
Z |
J |
C |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
ft2/ft |
6 x 2 x 3/8 |
0.375 |
17.27 |
5.08 |
2.13 |
12.8 |
17.8 |
5.93 |
1.87 |
8.33 |
2.85 |
2.85 |
0.749 |
3.61 |
8.72 |
6.65 |
1.23 |
x 5/16 |
0.313 |
14.83 |
4.36 |
3.19 |
16.0 |
16.1 |
5.37 |
1.92 |
7.34 |
2.62 |
2.62 |
0.775 |
3.23 |
7.94 |
5.89 |
1.24 |
x 1/4 |
0.250 |
12.21 |
3.59 |
4.80 |
20.8 |
13.8 |
4.60 |
1.96 |
6.18 |
2.31 |
2.31 |
0.802 |
2.75 |
6.88 |
4.97 |
1.26 |
x 3/16 |
0.188 |
9.42 |
2.78 |
7.44 |
28.7 |
11.1 |
3.70 |
2.00 |
4.89 |
1.91 |
1.91 |
0.829 |
2.20 |
5.58 |
3.93 |
1.28 |
5 x 4 x 1/2 |
0.500 |
25.03 |
7.36 |
4.40 |
6.40 |
22.0 |
8.80 |
1.73 |
11.5 |
15.4 |
7.70 |
1.45 |
9.77 |
31.7 |
15.3 |
1.36 |
x 3/8 |
0.375 |
19.82 |
5.83 |
7.47 |
10.1 |
18.8 |
7.52 |
1.80 |
9.44 |
13.2 |
6.60 |
1.50 |
8.08 |
26.3 |
12.4 |
1.39 |
x 5/16 |
0.313 |
16.96 |
4.99 |
9.58 |
12.8 |
16.6 |
6.64 |
1.82 |
8.25 |
11.7 |
5.85 |
1.53 |
7.06 |
22.9 |
10.7 |
1.41 |
x 1/4 |
0.250 |
13.91 |
4.09 |
12.8 |
16.8 |
14.1 |
5.64 |
1.86 |
6.89 |
10.0 |
5.00 |
1.56 |
5.90 |
19.1 |
8.85 |
1.43 |
x 3/16 |
0.188 |
10.70 |
3.15 |
18.1 |
23.4 |
11.3 |
4.52 |
1.89 |
5.40 |
7.98 |
3.99 |
1.59 |
4.64 |
15.0 |
6.87 |
1.45 |
5 x 3 x 1/2 |
0.500 |
21.63 |
6.36 |
2.40 |
6.40 |
16.9 |
6.76 |
1.63 |
9.20 |
7.37 |
4.91 |
1.08 |
6.34 |
18.2 |
10.8 |
1.19 |
x 3/8 |
0.375 |
17.27 |
5.08 |
4.80 |
10.1 |
14.7 |
5.88 |
1.70 |
7.71 |
6.50 |
4.33 |
1.13 |
5.35 |
15.6 |
8.90 |
1.23 |
x 5/16 |
0.313 |
14.83 |
4.36 |
6.38 |
12.8 |
13.2 |
5.28 |
1.74 |
6.78 |
5.86 |
3.91 |
1.16 |
4.72 |
13.8 |
7.77 |
1.24 |
x 1/4 |
0.250 |
12.21 |
3.59 |
8.80 |
16.8 |
11.3 |
4.52 |
1.77 |
5.70 |
5.05 |
3.37 |
1.19 |
3.98 |
11.7 |
6.47 |
1.26 |
x 3/16 |
0.188 |
9.42 |
2.78 |
12.8 |
23.4 |
9.08 |
3.63 |
1.81 |
4.50 |
4.09 |
2.73 |
1.21 |
3.16 |
9.23 |
5.06 |
1.28 |
5 x 2-1/2 x 1/4 |
0.250 |
11.36 |
3.34 |
6.80 |
16.8 |
9.9 |
3.96 |
1.72 |
5.11 |
3.28 |
2.62 |
0.991 |
3.12 |
8.36 |
5.28 |
1.18 |
x 3/16 |
0.188 |
8.78 |
2.59 |
10.1 |
23.4 |
7.99 |
3.20 |
1.76 |
4.05 |
2.69 |
2.15 |
1.02 |
2.49 |
6.68 |
4.16 |
1.20 |
5 x 2 x 3/8 |
0.375 |
14.72 |
4.33 |
2.13 |
10.1 |
10.72 |
4.29 |
1.57 |
5.98 |
2.35 |
2.35 |
0.737 |
3.00 |
6.82 |
5.43 |
1.06 |
x 5/16 |
0.313 |
12.70 |
3.74 |
3.19 |
12.8 |
9.76 |
3.90 |
1.62 |
5.31 |
2.17 |
2.17 |
0.762 |
2.70 |
6.24 |
4.83 |
1.08 |
x 1/4 |
0.250 |
10.51 |
3.09 |
4.80 |
16.8 |
8.48 |
3.39 |
1.66 |
4.51 |
1.93 |
1.93 |
0.790 |
2.32 |
5.43 |
4.10 |
1.10 |
x 3/16 |
0.188 |
8.15 |
2.40 |
7.44 |
23.4 |
6.90 |
2.76 |
1.70 |
3.59 |
1.60 |
1.60 |
0.816 |
1.86 |
4.41 |
3.25 |
1.11 |
4 x 3 x 3/8 |
0.375 |
14.72 |
4.33 |
4.80 |
7.47 |
8.23 |
4.12 |
1.38 |
5.36 |
5.19 |
3.46 |
1.09 |
4.37 |
11.1 |
6.93 |
1.06 |
x 5/16 |
0.313 |
12.70 |
3.74 |
6.38 |
9.58 |
7.46 |
3.73 |
1.41 |
4.75 |
4.72 |
3.15 |
1.12 |
3.88 |
9.90 |
6.08 |
1.08 |
x 1/4 |
0.250 |
10.51 |
3.09 |
8.80 |
12.8 |
6.46 |
3.23 |
1.45 |
4.03 |
4.11 |
2.74 |
1.15 |
3.30 |
8.41 |
5.10 |
1.10 |
x 3/16 |
0.188 |
8.15 |
2.40 |
12.8 |
18.1 |
5.24 |
2.62 |
1.48 |
3.21 |
3.35 |
2.23 |
1.18 |
2.63 |
6.68 |
4.00 |
1.11 |
4 x 2-1/2 x 3/8 |
0.375 |
13.44 |
3.95 |
3.47 |
7.47 |
7.00 |
3.50 |
1.33 |
4.68 |
3.27 |
2.62 |
0.910 |
3.33 |
7.86 |
5.57 |
0.976 |
x 5/16 |
0.313 |
11.64 |
3.42 |
4.79 |
9.58 |
6.39 |
3.20 |
1.37 |
4.18 |
3.01 |
2.41 |
0.938 |
2.99 |
7.09 |
4.93 |
0.994 |
x 1/4 |
0.250 |
9.66 |
2.84 |
6.80 |
12.8 |
5.58 |
2.79 |
1.40 |
3.56 |
2.65 |
2.12 |
0.966 |
2.56 |
6.09 |
4.16 |
1.01 |
x 3/16 |
0.188 |
7.51 |
2.21 |
10.1 |
18.1 |
4.56 |
2.28 |
1.44 |
2.85 |
2.18 |
1.74 |
0.993 |
2.05 |
4.89 |
3.29 |
1.03 |
Shape
h x b x t |
Design Wall
Thickness, t in.
Nominal
Wt lb/ft
Area, A
in2
b/t
h/t
Axis x - x
Axis Y-Y
Torsion |
Surface Area |
I |
S |
r |
Z |
I |
S |
r |
Z |
J |
C |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
in. |
in3 |
in4 |
in3 |
ft2/ft |
4 x 2 x 3/8 |
0.375 |
12.17 |
3.58 |
2.13 |
7.47 |
5.76 |
2.88 |
1.27 |
4.00 |
1.84 |
1.84 |
0.717 |
2.39 |
4.97 |
4.21 |
0.893 |
x 5/16 |
0.313 |
10.58 |
3.11 |
3.19 |
9.58 |
5.33 |
2.66 |
1.31 |
3.60 |
1.72 |
1.72 |
0.744 |
2.17 |
4.58 |
3.78 |
0.910 |
x 1/4 |
0.250 |
8.81 |
2.59 |
4.80 |
12.8 |
4.70 |
2.35 |
1.35 |
3.09 |
1.54 |
1.54 |
0.771 |
1.88 |
4.01 |
3.22 |
0.928 |
x 3/16 |
0.188 |
6.87 |
2.02 |
7.44 |
18.1 |
3.88 |
1.94 |
1.39 |
2.49 |
1.29 |
1.29 |
0.799 |
1.52 |
3.27 |
2.57 |
0.946 |
3-1/2 x 2-1/2 x 3/8 |
0.375 |
12.17 |
3.58 |
3.47 |
6.13 |
4.90 |
2.80 |
1.17 |
3.74 |
2.84 |
2.27 |
0.891 |
2.94 |
6.38 |
4.78 |
0.893 |
x 5/16 |
0.313 |
10.58 |
3.11 |
4.79 |
7.98 |
4.51 |
2.58 |
1.20 |
3.36 |
2.63 |
2.10 |
0.920 |
2.64 |
5.79 |
4.24 |
0.910 |
x 1/4 |
0.250 |
8.81 |
2.59 |
6.80 |
10.8 |
3.97 |
2.27 |
1.24 |
2.88 |
2.33 |
1.86 |
0.948 |
2.28 |
4.99 |
3.60 |
0.928 |
x 3/16 |
0.188 |
6.87 |
2.02 |
10.1 |
15.4 |
3.27 |
1.87 |
1.27 |
2.32 |
1.93 |
1.54 |
0.977 |
1.83 |
4.02 |
2.85 |
0.946 |
3-1/2 x 2 x 1/4 |
0.250 |
7.96 |
2.34 |
4.80 |
10.8 |
3.31 |
1.89 |
1.19 |
2.48 |
1.35 |
1.35 |
0.760 |
1.66 |
3.31 |
2.78 |
0.845 |
x 3/16 |
0.188 |
6.23 |
1.84 |
7.44 |
15.4 |
2.75 |
1.57 |
1.22 |
2.01 |
1.13 |
1.13 |
0.784 |
1.35 |
2.71 |
2.23 |
0.863 |
3-1/2 x 1-1/2 x 1/4 |
0.250 |
7.11 |
2.09 |
2.80 |
10.8 |
2.65 |
1.51 |
1.13 |
2.07 |
0.659 |
0.879 |
0.562 |
1.11 |
1.86 |
1.97 |
0.762 |
x 3/16 |
0.188 |
5.59 |
1.65 |
4.78 |
15.4 |
2.24 |
1.28 |
1.17 |
1.70 |
0.569 |
0.759 |
0.587 |
0.917 |
1.57 |
1.61 |
0.780 |
3 x 2-1/2 x 5/16 |
0.313 |
9.51 |
2.80 |
4.79 |
6.38 |
3.02 |
2.01 |
1.04 |
2.62 |
2.26 |
1.81 |
0.898 |
2.30 |
4.53 |
3.56 |
0.827 |
x 1/4 |
0.250 |
7.96 |
2.34 |
6.80 |
8.80 |
2.68 |
1.79 |
1.07 |
2.27 |
2.01 |
1.61 |
0.927 |
1.99 |
3.93 |
3.03 |
0.845 |
x 3/16 |
0.188 |
6.23 |
1.84 |
10.1 |
12.8 |
2.23 |
1.49 |
1.10 |
1.84 |
1.68 |
1.34 |
0.956 |
1.62 |
3.19 |
2.42 |
0.863 |
3 x 2 x 5/16 |
0.313 |
8.45 |
2.49 |
3.19 |
6.38 |
2.45 |
1.63 |
0.992 |
2.20 |
1.27 |
1.27 |
0.714 |
1.64 |
2.97 |
2.72 |
0.744 |
x 1/4 |
0.250 |
7.11 |
2.09 |
4.80 |
8.80 |
2.21 |
1.47 |
1.03 |
1.92 |
1.15 |
1.15 |
0.742 |
1.44 |
2.63 |
2.35 |
0.762 |
x 3/16 |
0.188 |
5.59 |
1.65 |
7.44 |
12.8 |
1.86 |
1.24 |
1.06 |
1.57 |
0.980 |
0.980 |
0.771 |
1.18 |
2.17 |
1.89 |
0.780 |
3 x 1-1/2 x 1/4 |
0.250 |
6.26 |
1.84 |
2.80 |
8.80 |
1.74 |
1.16 |
0.972 |
1.58 |
0.560 |
0.747 |
0.552 |
0.949 |
1.50 |
1.66 |
0.678 |
x 3/16 |
0.188 |
4.96 |
1.46 |
4.78 |
12.8 |
1.49 |
0.993 |
1.01 |
1.31 |
0.488 |
0.651 |
0.578 |
0.794 |
1.27 |
1.36 |
0.696 |
3 x 1 x 3/16 |
0.188 |
4.32 |
1.27 |
2.12 |
12.8 |
1.12 |
0.747 |
0.939 |
1.04 |
0.178 |
0.356 |
0.374 |
0.452 |
0.546 |
0.833 |
0.613 |
2-1/2 x 2 x 1/4 |
0.250 |
6.26 |
1.84 |
4.80 |
6.80 |
1.38 |
1.10 |
0.866 |
1.43 |
0.962 |
0.962 |
0.723 |
1.22 |
1.98 |
1.91 |
0.678 |
x 3/16 |
0.188 |
4.96 |
1.46 |
7.44 |
10.1 |
1.17 |
0.936 |
0.895 |
1.18 |
0.825 |
0.825 |
0.752 |
1.01 |
1.64 |
1.55 |
0.696 |
2-1/2 x 1-1/2 x 1/4 |
0.250 |
5.41 |
1.59 |
2.80 |
6.80 |
1.06 |
0.848 |
0.816 |
1.15 |
0.461 |
0.615 |
0.538 |
0.793 |
1.14 |
1.35 |
0.595 |
2-1/2 x 1-1/2 x 3/16 |
0.188 |
4.32 |
1.27 |
4.78 |
10.1 |
0.923 |
0.738 |
0.853 |
0.965 |
0.407 |
0.543 |
0.566 |
0.670 |
0.977 |
1.11 |
0.613 |
2-1/2 x 1 x 3/16 |
0.188 |
3.68 |
1.08 |
2.12 |
10.1 |
0.671 |
0.537 |
0.788 |
0.748 |
0.147 |
0.294 |
0.369 |
0.376 |
0.427 |
0.680 |
0.530 |
2-1/4 x 2 x 3/16 |
0.188 |
4.64 |
1.37 |
7.44 |
8.77 |
0.901 |
0.801 |
0.811 |
1.01 |
0.748 |
0.748 |
0.739 |
0.927 |
1.39 |
1.38 |
0.655 |
2 x 1-1/2 x 3/16 |
0.188 |
3.68 |
1.08 |
4.78 |
7.44 |
0.515 |
0.515 |
0.691 |
0.671 |
0.325 |
0.433 |
0.549 |
0.547 |
0.696 |
0.868 |
0.530 |
2 x 1 x 3/16 |
0.188 |
3.04 |
0.896 |
2.12 |
7.44 |
0.360 |
0.360 |
0.634 |
0.501 |
0.115 |
0.230 |
0.358 |
0.300 |
0.311 |
0.528 |
0.446 |
Related Resources:
