Structural Steel Angle Section Properties, Equal Leg BSI BS EN 10056
Structural Materials Menu
Engineering Materials Menu
This webpage details Section Properties for Structural Steel Angle BSI BS EN 10056.
Structural Steel Angle Equal Leg Section Properties: This European Standard specifies requirements for the nominal dimensions of hot-rolled equal and equal leg angles. This European Standard does not apply to angles with square roots. Tolerances for equal and unequal leg angles are given in EN 10056-2.
Shape Designation d x bw x t |
Section Dimensional Data |
Inside Corner Radius |
External Edge Radius |
Area of Section |
d (mm) |
t (mm) |
R1 (mm) |
R (mm) |
A (cm2) |
250 x 250 x 35 |
250 |
35 |
18 |
9 |
163 |
250 x 250 x 32 |
250 |
32 |
20 |
10 |
150 |
250 x 250 x 28 |
250 |
28 |
18 |
9 |
133 |
250 x 250 x 25 |
250 |
25 |
20 |
10 |
119 |
200 x 200 x 24 |
200 |
24 |
18 |
9 |
90.6 |
200 x 200 x 20 |
200 |
20 |
18 |
9 |
76.3 |
200 x 200 x 18 |
200 |
18 |
18 |
9 |
69.1 |
200 x 200 x 16 |
200 |
16 |
18 |
9 |
61.8 |
180 x 180 x 18 |
180 |
18 |
18 |
9 |
61.9 |
180 x 180 x 16 |
180 |
16 |
18 |
9 |
55.4 |
160 x 160 x 15 |
160 |
15 |
17 |
8.5 |
46.1 |
150 x 150 x 18 |
150 |
18 |
16 |
8 |
51 |
150 x 150 x 15 |
150 |
15 |
16 |
8 |
43 |
150 x 150 x 12 |
150 |
12 |
16 |
8 |
34.8 |
150 x 150 x 10 |
150 |
10 |
16 |
8 |
29.3 |
130 x 130 x 12 |
130 |
12 |
14 |
7 |
30 |
120 x 120 x 15 |
120 |
15 |
13 |
6.5 |
33.9 |
120 x 120 x 12 |
120 |
12 |
13 |
6.5 |
27.5 |
120 x 120 x 10 |
120 |
10 |
13 |
6.5 |
23.2 |
120 x 120 x 8 |
120 |
8 |
13 |
6.5 |
18.7 |
100 x 100 x 15 |
100 |
15 |
12 |
6 |
27.9 |
100 x 100 x 12 |
100 |
12 |
12 |
6 |
22.7 |
100 x 100 x 10 |
100 |
10 |
12 |
6 |
19.2 |
100 x 100 x 8 |
100 |
8 |
12 |
6 |
15.5 |
90 x 90 x 12 |
90 |
12 |
11 |
5.5 |
20.3 |
90 x 90 x 10 |
90 |
10 |
11 |
5.5 |
17.1 |
90 x 90 x 9 |
90 |
9 |
11 |
5.5 |
15.5 |
90 x 90 x 8 |
90 |
8 |
11 |
5.5 |
13.9 |
90 x 90 x 7 |
90 |
7 |
11 |
5.5 |
12.2 |
90 x 90 x 6 |
90 |
6 |
11 |
5.5 |
10.6 |
80 x 80 x 10 |
80 |
10 |
10 |
5 |
15.1 |
80 x 80 x 8 |
80 |
8 |
10 |
5 |
12.3 |
80 x 80 x 6 |
80 |
6 |
10 |
5 |
9.35 |
75 x 75 x 8 |
75 |
8 |
9 |
4.5 |
11.4 |
75 x 75 x 6 |
75 |
6 |
9 |
4.5 |
8.73 |
70 x 70 x 10 |
70 |
10 |
9 |
4.5 |
13.1 |
70 x 70 x 8 |
70 |
8 |
9 |
4.5 |
10.6 |
70 x 70 x 7 |
70 |
7 |
9 |
4.5 |
9.4 |
70 x 70 x 6 |
70 |
6 |
9 |
4.5 |
8.13 |
65 x 65 x 7 |
65 |
7 |
9 |
4.5 |
8.7 |
60 x 60 x 10 |
60 |
10 |
8 |
4 |
11.1 |
60 x 60 x 8 |
60 |
8 |
8 |
4 |
9.03 |
60 x 60 x 6 |
60 |
6 |
8 |
4 |
6.91 |
60 x 60 x 5 |
60 |
5 |
8 |
4 |
5.82 |
50 x 50 x 8 |
50 |
8 |
7 |
3.5 |
7.41 |
50 x 50 x 6 |
50 |
6 |
7 |
3.5 |
5.69 |
50 x 50 x 5 |
50 |
5 |
7 |
3.5 |
4.8 |
50 x 50 x 4 |
50 |
4 |
7 |
3.5 |
3.89 |
50 x 50 x 3 |
50 |
3 |
7 |
3.5 |
2.96 |
45 x 45 x 6 |
45 |
6 |
7 |
3.5 |
5.09 |
45 x 45 x 5 |
45 |
5 |
7 |
3.5 |
4.3 |
45 x 45 x 4.5 |
45 |
4.5 |
7 |
3.5 |
3.9 |
45 x 45 x 4 |
45 |
4 |
7 |
3.5 |
3.49 |
45 x 45 x 3 |
45 |
3 |
7 |
3.5 |
2.66 |
40 x 40 x 6 |
40 |
6 |
6 |
3 |
4.48 |
40 x 40 x 5 |
40 |
5 |
6 |
3 |
3.79 |
40 x 40 x 4 |
40 |
4 |
6 |
3 |
3.08 |
40 x 40 x 3 |
40 |
3 |
6 |
3 |
2.35 |
35 x 35 x 4 |
35 |
4 |
5 |
2.5 |
2.67 |
30 x 30 x 5 |
30 |
5 |
5 |
2.5 |
2.78 |
30 x 30 x 4 |
30 |
4 |
5 |
2.5 |
2.27 |
30 x 30 x 3 |
30 |
3 |
5 |
2.5 |
1.74 |
25 x 25 x 5 |
25 |
5 |
3.5 |
1.75 |
2.26 |
25 x 25 x 4 |
25 |
4 |
3.5 |
1.75 |
1.85 |
25 x 25 x 3 |
25 |
3 |
3.5 |
1.75 |
1.42 |
20 x 20 x 3 |
20 |
3 |
3.5 |
1.75 |
1.12 |
