Frustum of Cone Volume and Area Equation and Calculator
Volume Equation and Calculation Menu
A frustum may be formed from a right circular cone by cutting off the tip of the cone with a cut perpendicular to the height, forming a lower base and an upper base that are circular and parallel. The problem can be generalized to other cones and n-sided pyramids but for the moment consider the right circular cone.
Frustum of Cone
Frustrum of Cone Volume and Area Equation
Input Volume Data
Height h (in, mm) =
Large Diameter D (in, mm) =
Small Diameter d (in, mm) =
Result
Volume V (in3, mm3) =
Input Area Data
Distance s (in, mm) =
Result
Area (in2, mm2) =
