Spherical Wedge Volume and Area Calculator and Equation
Volume Equation and Calculation Menu
Spherical Wedge Volume and Area Equation and Calculator
A spherical wedge or ungula is a portion of a ball bounded by two plane semidisks and a spherical lune (termed the wedge's base ). The angle between the radii lying within the bounding semidisks is the dihedral angle of the wedge α .
Input Volume Data
Radius r (in, mm) =
Angle  (degrees) =
Result
Volume V (in3, mm3) =
Input Area Data
Radius r (in, mm) =
Angle  (degrees) =
Result
Area (in2, mm2) =
