Mechanical Design and Engineering Process
Prof. Dr. Musa K. AlAjlouni
189 pages
1992
Premium Membership Required for this Book
Open: Mechanical Design and Engineering Process
Mechanical Engineering design is a study of design-making processes. It utilizes mathematics, the material sciences and the engineering-mechanics sciences. In this course concentration will be on machine elements design rather than machine design. This book will cover the following topics:
Introduction to Mechanical Engineering Design, Part I
- The Nature of Mechanical Engineering Design
- Design phases
- Design Procedure
- Design Considerations
- Standards and Codes
- Materials Selection
- Dimensions, Tolerances, Limits and Fits
- Surface finish
- Relation between manufacturing processes, tolerances and surface finish
Stress Analysis, Part II
- Simple Stresses
- Types of Loading
- Combined stresses
- Failure theories
Design of Mechanical Elements
- Shafts, axles and their components
- Bearings
- Couplings
- Screws
- Welding and Riveted joints
- Mechanical Springs
- Clutches
- Brakes
- Belt
- Chain
- Gears
- Machine Design, Abdul Mubeen, 1995, Second edition, Khanna Publishers.
- Machine Design: Theory and Practice, A. D. Deutschman, W. J. Maichels and C.E. Wilson, 1975, First edition, Macmillan Publishing Company.
- Machine Design, A .CAD approach, A. D. Demarogonas, 2001, First edition, Wiley and sons Publishing Company.
- Design for Manufacturability and Assembly DFM DFMA Premium Resources
- Fundamentals of Machine Design, Volume 1
- Machine Design (S.I. Units) Book
- Mechanics and Machine Design, Equations and Calculators
- Disk Clutch Power Transmission Formula and Calculator
- Beam Three Supports Uniform Load, Moments, Shear, Reactions and Deflections Equations and Calculator
- Frame Deflections with Concentrated Angular Displacement Applied on Horizontal Member Calculator
- Bolt Shear AISC Stress Calculator Calculator will determine bolt stress in tension and shear per AISC 9th Edition Manual (ASD)
- Torsional Rigidity of Equivalent Solid Shaft vs Hollow Shaft of Same Length Formula and Calculator
