Beam, Deflection and Stress Equations Calculator for Both Ends Overhanging Supports, Load at any Point Between
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam with Both Ends Overhanging Supports, Load at any Point Between.
Beam Section Modulus Z
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Beam Stress
Beam Stress at Load:
General Beam Stress
If cross-section is constant, this is the maximum stress.
Open: Stress at Load Beam Calculator
General Beam Stress at any Given Point
Between supports:
Beam Stress For area length a,
Open: Stress Between Supports Length a Beam Calculator
Beam Stress For area of length b,
Beam Stress area of length b
Open: Stress Between Supports Length b Beam Calculator
Beyond supports s = 0
Beam Deflection at Critical Locations/Points
Beam Deflection at any Point
Beam Deflection Between supports for overhanging end of length c
Open: Deflection overhanging end of length c Beam Calculator
Beam deflection for overhanging end of length d
Open: Deflection overhanging end of length d Beam Calculator
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s =  Beam Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
u = Some distance as indicated inches (mm)
a, b, c & d = Some distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
l = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 405 or,
  • Machinery's Handbook, 23st Edition, Page 261 or,
  • Machinery's Handbook, 27st Edition, Page 26
