Beam Deflection and Stress Equations Calculator for Cantilevered Beam with One Load Applied at End
Structural Beam Deflection, Stress Equations and calculator for a Cantilevered Beam with One Load Applied at End.
Open
Beam Stress Cantilevered Beam One Load Applied at End Calculator
Beam Stress at specific point
Beam Stress at the support (must be constant cross section)
Beam Deflection at specified point
Beam Deflection at the unsupported end
W = | Load | lbs | (N) |
s = | Stress at the cross-section being evaluated | lbs/in2 | (N/mm2) |
Some distance as indicated | inches | (mm) |
Z = |
z = |
- Please note letter "
" (lower case "L") is different than "I" (Moment of Inertia).
- Machinery's Handbook, 21st Edition, Page 408 or,
- Machinery's Handbook, 23st Edition, Page 264 or,
- Machinery's Handbook, 27st Edition, Page 265
- Beam Deflection Equations / Calculator Supported on Both Ends Uniform Loading
- Beam Deflection Equations / Calculator Supported on Both Ends Single Load at Center
- Beam Deflection Equations / Calculator Supported on Both Ends Loaded at any Location
- Beam Deflection Calculator Supported on Both Ends Loaded Two equal Loads
- Beam Deflection Equations / Calculator with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations
- Beam Deflection Equations / Calculator with End Overhanging Supports and a Single Load
- Beam Deflection Calculator Cantilevered Beam with One Load Applied at End
- Beam Deflection Equations / Calculator Cantilevered Beam with Uniform Load
- Beam Deflection Calculator Supported on One End, Rigid one End With Uniform Load
- Beam Deflection Equations / Calculator Cantilevered Beam with Load at Location Between Support and Load
