Bending, Deflection and Stress Equations Calculator for Fixed at One End, Supported at the Other, Load at any Point
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Fixed at One End, Supported at the Other, Load at any Point.
Beam Lengths m & n
(Used in many equations)
m = (l + a)(l + b) +al
n = al(l + b)
Open: Lengths m and n Calculator
Beam Loads and Moment at Reaction points as Defined
Open: Loads at Reaction points as Defined Beam Calculator
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Beam Stress at any Given Point
Beam Stress Between point of fixture and load
Beam Stress Between support and load
Open: Stress Between point of fixture and load and Support Calculator
Beam Stress at Critical Locations/Points
Open: Greatest Positive Stress at point of fixture and Negative Stress at Load Calculator
Beam Deflection at any Point
Beam Deflection Between point of fixture and load
Beam Deflection Between support and load
Open: Deflection at point of fixture and load and Between Support at Load Calculator
Beam Critical Deflections
Open: Deflection at Load Calculator
W = | Load | lbs | (N) |
s = | Beam Stress at the cross-section being evaluated | Lbs/in2 | (N/mm2) |
u = | Some distance as indicated | inches | (mm) |
a, b, c & d = | Some distance as indicated | inches | (mm) |
L = | Some distance as indicated | inches | (mm) |
m, n = | Some calculated distance as indicated | inches | (mm) |
l = | Some distance as indicated | inches | (mm) |
Z = |
z = |
- Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
- Machinery's Handbook, 21st Edition, Page 405 or,
- Machinery's Handbook, 23st Edition, Page 261 or,
- Machinery's Handbook, 27st Edition, Page 26
- Combined Loading on Circular Beam or Shaft in Direct Tension and Deflection Equation and Calculator
- Combined Loading on Rectangular Beam or Shaft in Direct Compression and Deflection Equation and Calculator
- Combined Loading on Rectangular Beam or Shaft in Direct Tension and Deflection Equation and Calculator
- Combined Loading on Circular Shaft in Direct Compression and Torsion Equation and Calculator
- Combined Loading on Circular Shaft in Direct Tension and Torsion Equation and Calculator
- Maximum Shear Stress Theory Fatigue of a Shaft or Axle Formula and Calculator
- Shaft Torsional Deflection and Rigidity Formulas and Calculator
- Static Loading Shaft or Axle Analysis Formula and Calculator - Most shafts are subject to combined bending and torsion, either of which may be steady or variable. Maximum Shear Stress and Von Mises Stress
- Combined Loading on Offset Link, Circular Cross Section, in Direct Tension Equation and Calculator
- Beam Deflection Equations / Calculator Cantilevered Beam with One Load Applied at End
