Churchill Friction Factor Formulae and Calculator
Churchill Friction Factor Equation and Calculator
This equation for the friction factor was proposed by Stuart Churchill and published in Chemical Engineering magazine in November 1977.
Churchill Friction this is an explicit equation for solving for the friction factor and is expressed as
Equation 1
Equation 2
Equation 3
f = friction factor, (dimensionless)
ε = absolute pipe roughness, (in, mm) depends on the condition of the pipe. It ranges from 0.001 to 0.01.
d = inside diameter of pipe, (in, mm)
Re = Reynolds number, (dimensionless)
The Churchill equation for the friction factor yields comparable results with that obtained using the Colebrook-White equation.
- Liquid Pressure Drop in Pipe and Pipe Fittings Spreadsheet Calculator
- Friction Loss - Fluid Flow Hydraulic and Pneumatic
- Darci's Equation Fluids Flow Equation
- Pipe Flow/Friction Factor Calculations with Excel Training - 3 PDH
- Unwin Gas Change of Pressure Calculator and Formulas
- Gas Flow Rate Through Orifice Equations and Calculator per. ISO 5167
- Natural Gas Pipe Flow Rate Calculator
- Appliance Gas Pipe Flow Rate Capacities
- Transmission Gas Line Isothermal Flow Equations and Calculator
- Fluids Discharge Measurement Structures and Systems , Basic Principles of Fluid Flow as Applied to Measuring Systems
- Hydraulic and Pneumatic Design and Engineering
- Piping Calculations Manual,
E. Shashi Menon
SYSTEK Technologies, Inc
