Scissor Lift Jack Force Center Load Calculator
Mechanics Machines Menu
Open webpage with mathematical proof (Equations and Calculators updated: April 20, 2012)
Equations and proof
Open: Scissor Lift Jack Force Center Load Proof Equations
A scissors lift uses linked, folding supports in a criss-cross 'X' pattern, known as a pantograph. The extension is achieved by applying pressure to the outside of a set of supports located at one end of the lift, elongating the crossing pattern. This can be achieved through hydraulic, pneumatic, mechanical or simply muscular means.
It may require no power to return to its original position, but simply a release of the original pressure.
Scissor Lift Center Loaded Actuator
Scissor Lift Center Loaded Force Calculations
Variables
Weight Payload & Platform W (N, lbs) =
Angle Φ (Degrees) =
Results
Force for Equilibrium at Load Rx (N, lbs) =
Load Ry (N, lbs) =
