Solid Shaft with Simple Bending Diameter Equation and Calculator
Strength and Mechanics of Materials Menu
Diameter of Solid Shaft Subjected to Simple Bending Equation and Calculator
D = [ 32 Mb / ( π σyd )] (1/3)
where
D = diameter of shaft, m (in)
Mb = bending moment, Nm (lbf in)
σy = stress (tensile or compressive), MPa (psi)
- Diameter of Solid Shaft with Torsion Equation and Calculator
- Torsional Stiffness Solid Shaft Equations and Calculator
- Torsional Deflection of Shaft
- Torsional Deflection of Solid Cylinder Calculator
- Shaft Torsional Deflection and Rigidity Formulae and Calculator
- ASME Shaft Design Allowable Stress and Diameter equations and calculators
- Shaft Couplings Design Equation and Calculator
- Cylindrical Shaft and Maximum Torque Moment
- Torsional Stress Calculator and Equations for Hollow Cylinders
Source: Shigley, Joseph E., and Charles R. Mischke, Mechanical Engineering Design, 5th ed., New York: McGraw-Hill, 1989.
