Sprocket Chain Length Formulae and Calculator
Gear Design and Selection Application
Chain Length For Two Sprockets Formulas and Calculator
It is sometimes necessary to fix the center-to-center distance of the sprockets to accommodate existing constraints or mechanical design considerations. An example of this may be the case where a chain and sprocket assembly are fixed to a nonadjustable motor shaft and required to drive a set of meshing gears.
Chain length is a function of the number of teeth of the drive and driven sprockets as well as the center-to-center distance. Here is an example of the process required to calculate chain length given a center distance and the sprocket teeth numbers.
Note: Chain length is customarily expressed in (even numbers) of pitch units since chains can only be shortened or lengthened by multiples of their pitch units. If an odd number of pitches is required then a special link called an offset link is used.
Preview: Chain Length For Two Sprockets Calculator
Chain Length in Pitch Units For Two Sprockets Equation
L = 2 [ C cos a + ( N + n ) / 4 + ( a / 360 ) ( N- n ) ]
Since each pitch unit represents 1 chain link, and it is not possible to have a fractional link, we must round off the chain length to a whole number. Remember, it is best practice to use EVEN numbers of chain links.
Note: Do not round down. This causes the chain to be too tight and the added tension can damage sprockets, shafts and cause premature chain failure.
L = Chain length in pitch (Pitch Units),
Llin = Linear length of chain,
N = Drive Sprocket number of teeth,
n = Driven Sprocket number of teeth,
a = angle (deg) sin a = DF / AD,
P = Pitch of sprockets,
Sd = Linear distance from A to D,
C = Distance From (A to D) / P Center Distance between sprockets expressed in Pitch Units
- Sprocket Pitch Diameter Formulas and Calculator
- Precision Sprockets Caliper Diameters per ANSI/ASME B29.1M
- Sprocket Center Distance Equation and Calculator
- Two Gears Sprocket Speed and Gear Ratio Equation and Calculator
- Roller Chains Review - Engineers Edge
- Roller Chain Sprocket Diameters Dimensions per. ANSI/ASME B29.1M
Reference ANSI/ASME B29.1M
